The one and only GABE's '13 GT Build Thread!
#301
Just installed MonzterAuto's harnesses that make the tails light up sequentially when braking, locking and unlocking the car, as well as the turn-signal function
The install process:
The single fastener that needs to be removed, then move that plastic panel away from the body to have access to the wiring:
The factory tail light harness un-clipped from the body harness:
The new harness installed inline:
#302
JMHO, but it looks like the emergency flashers flashing when you brake (as it appears to me). It could be confusing, and someone may not see them as brake lights but as emergency flashers, and they may not realize the difference until too late.
#303
If they're emergency flashers, they should be braking anyways. They only go through the sequence once and then stay illuminated. Similar to the BMW and other high end German cars that have "staged" brake lights depending on how hard you press the pedal - slam on it in a panic stop and it flashes all the lights a couple times then illuminates ALL the taillight bulbs; press down lightly and only the normal brake lights illuminate with no flash.
#304
Yeah, when I step on the brake pedal the side lights sequence outward then they stay lit, and then my third brake light pulses then stays solid too.
I'll have a new video soon
Meanwhile, I just got a couple new flip keys for the car
#307
On sale currently for $97 shipped
http://store.monzterauto.com/product...ight-sequencer
http://www.ebay.com/itm/221074596583...84.m1497.l2649
$21.95 each
$21.95 each
#308
#309
Currently waiting to be installed: McLeod stainless steel braided clutch line, Amsoil 600-series DOT4 brake fluid, a new left rear axle seal and bearing, and some fresh Amsoil 75W140 rear axle fluid along with some Ford Racing friction modifier.
Haven't driven the car in about a week, since I found out about the leaking seal, since I'm pretty sure it's been leaking for some time and don't want to do further/possible damage to the gears.
Appt for the seal repair currently made for this Friday
#315
It would be, if I didn't have non-stock rear-end fluid in there, a slew of aftermarket suspension parts installed, an aftermarket 1-piece driveshaft, and so on.
I wanted to change the fluid soon anyway, this will just add about an hour to the job, and not a lot more $$
#316
Today I installed the new Ford Racing twin-65mm throttle body, running it for now off the twin-60 JDM tune, which they say is OK to do.
However, I can't push it much until I get a new tune for the new VMP fuel pump voltage booster
First start-up:
Was a little surprised to see this oil in the elbow ... guess I really need to think about a dual-catch-can set-up.
First start-up:
#317
Wow, I haven't updated this thread in a while ...
The twin-65mm TB didn't stay, I ended up removing it and sold it to my GF for her to put/use on her GT500.
New AMR wheels test-fitted about 1-2 weeks ago:
Roush lower grille delete kit finally installed yesterday, along with HomeDepot-bought black mesh behind it to keep rocks/other debris from hitting the heat exchanger:
Man was I psyched to see it cleared the VMP heat exchanger, lol ... :
New summer tires came in a couple weeks ago, should be mounted/balanced onto the new AMR's tomorrow, if all goes according to plan
New 14" rear '13-'14 GT500 rotors are here, waiting to be installed along with new Hawk HPS brake pads and the new caliper brackets that relocate the calipers so the larger rotors will fit:
#319
Gabe, R u dumping the 18 inch wheel set up?, What prompted you to change to a staggered set up? Im amazed at how much you've done to your ride, very nice.
