06 to 07 engine/trans wiring harness swap
Administrator, Shop Manual PDF Poster, Parts Locator & Spam Bot Eliminator!!
Received 2,861 Likes
I'm Happy To Be of Service! It's Looking Like Mid Next Week Before I get Some Access Back So Good You Got it Figured.
We Got a New Wiring Issue on this thread & I Tell You it's Gonna Be Quite a Challenge For This New Member!
https://themustangsource.com/forums/...6/#post7084189
I Know What it's Like To Chase an Issue and Finally Beat it! It's Great and When A Member Solves an Issue Like That We All Enjoy & Benefit. Might Be in a Week Might Be Years But it's Our Legacy Posts Which Make Us THE MUSTANG SOURCE!
Any Details on Your Journey Are Just That Much Better Info For The Site & Others Who Venture Down Similar Paths!
KC
KC
Here's what my plan was. Using the 2007 harness as a base and making it match and work in a 2006.
Trans
done 34 goes to 10 white/red
done 23 goes to 2 light blue/pink
done 11 goes to 1 white/yellow
done add 18 trans OD cancel from BEC A9 tan/white DARK BLUE?LIGHT GREEN Remove
NEED
Not there, Did NOTHING 30 speed control deactivator switch signal (not on 07) white Need to trace other end!!!
engine
done 3 A/C clutch relay control from BEC B8 grey/white trace and replicate REMOVE pink/black PCV heater signal wire. trace to end
done 4 light green/violet high speed fan relay to 7
done 4 A/C clutch cycling pressure switch trace on 06 harness and duplicate Dark blue/yellow OR dark green/Orange
done 6 light green/black EVAP canister purge valve goes to 8
done 7 dark blue low speed fan relay to 6
NEED
done 13 generator communication
yellow/blue on 2006, need to trace and duplicate
not equipped 43 intake manifold tuning valve monitor dark blue/light green need to trace and possibly replicate
not equipped 50 intake manifold tuning valve dark blue/yellow need to trace and possibly replicate 07 wire is same color, no idea where it goes
done 65 voltage supplied at all times overload protected (not on the 07) NEED TO TRACE ON THE 06 AND POSSIBLY REPLICATE
not there. did nothing 64 remove DARK BLUE/YELLOW only needed for 5.4 SHOULD BE EMPTY
not there, did nothing 68 REMOVE YELLOW
BEC CONNECTION
done remove E5 to A9 Trans OD cancel switch tan/white to trans 18
done add B8 A/C clutch relay control Grey/white to engine 3
done add C5 Voltage supplied at start and run RED
done D5 CHECK other end...... 06 is violet yellow, 07 is red
done F3 voltage supplied at all times light blue/red
done left it where it was, injector power F6 Voltage supplied at start and run RED need to trace and possibly replicate. no other end on 06 that I see. on 07 it goes to engine 23
moved F8 ground to body plug, bottom row, 3rd from right.
Removed
yellow/blue to alternator. Replaced wire, can be removed
yellow/light blue for oil temp signal wire
2006 2007
good 1 light blue/pink blue violet 966 PC B
*good 2 orange black orange black 923 TFT
3 red white purple blue/white? 1862 TO BEC
*good 4 white red white red 912 PC C
*good 5 black green black green 236 SSD
*good 6 pink black pink black 971 SS C
??????11 white yellow white green 925 PC A diagram shows white yellow on both
*good 12 grey red grey red 359 TRANS CONTROLS....
*good 13 empty empty EMPTY
??????14 purple white/yellow purple green 126 TCC shows violet yellow on 07 diagram
possibly good 15 purple pink purple orange 315 SS B
*good 16 orange yellow orange yellow 237 SS A
Trans
NEED
engine
NEED
BEC CONNECTION
Removed
2006 2007
D--amn, You are A Good Planner!
KC
KC
