05 Manuel Gt Knocking
Old Mar 22, 2018 | 11:28 AM
Alexi's Avatar
Hi guys, I have a 05 gt std with 111,000miles on it. It runs awesome but sometimes when I come to a complete stop it starts knocking. I get scared and turn it off and I imediately turn it back on and the knocking is gone. Any ideas, has to me twice already. Once after a burn out. So I guessed it was that but the other time I was not fooling around with it. Just regular fun cruising and when I came to a complete stop it started knocking. Again the wierd thing is that you shutoff and restart the engine and its gone.. im scared. Thanks in advance.
Old Mar 22, 2018 | 04:49 PM
m05fastbackGT's Avatar
When was the last time you changed the spark plugs and fuel filter? If it's been quite awhile, I'd start there first
Old Mar 23, 2018 | 06:54 AM
Alexi's Avatar
Thanks for the reply I bought this used like maybe to months ago so dont really know. All i have done is change the oil. Going to get it scaned today, fingers crossed. Car has since been running fine. Wierd one huh!
Old Mar 23, 2018 | 08:06 AM
Paris MkVI's Avatar
A full service on a used car happens one of two ways:
[1] Previous owner has the car fully serviced, and bumps the price to cover it. You pay for it.
[2] Previous owner does not have the car fully serviced. You buy it and figure out what has or hasn't been done. You pay for it.
No service records handed to you when you buy the car? Assume the worst.
Old Mar 23, 2018 | 01:33 PM
Couldn't agree more
Old Mar 24, 2018 | 05:53 PM
Cavero's Avatar
Check engine light on? Any codes?
I've heard of getting a bad tank of gas causing issues like that. Has it been going on for more than one fill up?
My other thought would be cam phasers...they're known to be weak on the modular motors and can start failing around the 100k mi mark.
Anything like this?
Old Mar 25, 2018 | 11:46 AM
Alexi's Avatar
K guys I got it scanned no codes except for the o2 sensor due to headers and piping. The mech said that it seems that the ignition coils are starting to go. He said I should start there scince he pulled some spark plugs and they seemed pretty new.
I already order ignition coils for my f150 so I will try them on the car and rescan. If it scans better then just buy new good coils maybe msd. My first rhought was also the phazers but lets start with the cheapest this first. Fingers crossed.
Old Mar 25, 2018 | 11:48 AM
Alexi's Avatar
Anything like this?
https://www.youtube.com/watch?v=-YFOxIZEWZM
Omg!! Thats it! Well sounds pretty dam close.
Old Mar 25, 2018 | 02:15 PM
You would think the mech would know for certain as to whether or not it's ignition coils. What about having diagnostic testing done at your local dealership to make certain
Old Mar 25, 2018 | 03:38 PM
Alexi's Avatar
He did say for sure the coils are bad or atleast show up on the scanner as bad. But the car isnt sputering or anything.
Old Mar 25, 2018 | 05:58 PM
Cavero's Avatar
If it's making noise at idle and goes away when your revs go up, it sounds like that may be your culprit. To get a better idea if its really the case, try to figure out if the noise is really coming from them or not. The phasers are under the valve covers at the front of the engine. Try to listen to see what side it's coming from. You can use a mechanic's stethoscope if you have one, or I've even used a screwdriver. Just put the pointy end on the valve cover and put your ear on the end of the handle (and not the other way around ). Move it around and see if you can pinpoint it coming from the front of the valve cover on one side or the other.
Old Mar 25, 2018 | 07:40 PM
I stand corrected, as I misinterpreted. So if he said the coils are definitely bad, then I would start there. I'd also follow Cavero's recommendation about the cam phasers as well
SVO500
Jun 12, 2013 03:06 PM
JHL981
V6 Performance Mods
Aug 7, 2011 04:17 PM
norcalmustang
Dec 30, 2004 06:53 AM
s197pilot
17
Nov 26, 2004 01:46 PM
