Hidden Anti Theft Kill Switch Suggestions*
Old Mar 21, 2018 | 01:22 PM
Does anyone have a suggestion as to which wire I can hook a kill switch up to. So my car will not start unless I flick the switch. Any suggestions as to where to mount the switch would be helpful as well. Thanks for the help
Old Mar 22, 2018 | 01:13 PM
07 Boss's Avatar
Uhhhh..... do you want it to not crank or just not start? I guess you can put a cut off switch anywhere along the fuel or ignition. Or you can utilize the components that are already on the car like neutral safety or clutch switch. Put the switch anywhere you want. I'm not sure what you are looking for here, do you want it hidden or easily accessible? Maybe you need a kill switch because you moved your battery??? You can get one of those from Jegs or Summit. What is the purpose of the kill switch, kinda vague here? if you get a battery cutoff switch it has to be mounted on the rear most part of the car.
Old Mar 22, 2018 | 03:00 PM
Evil_Capri's Avatar
On one of my previous Capris the previous owner installed a switch under the driver seat for the fuel pump. Car would crank but not start when switch was used.
I've never thought to install one on any of my other cars, but it worked.
Old Mar 23, 2018 | 06:42 AM
Thanks Gents. I want it hidden. I want it so my car will be harder to steal. I suppose it would be better if it didn't crank over. I have an auto trans
Old Mar 23, 2018 | 04:01 PM
berzerk_1980's Avatar
There's a perfect place for switches in the center console of my '14. It's a knockout panel that's easily replaceable.
Any such luck on early S197s?
Old Mar 26, 2018 | 10:47 AM
07 Boss's Avatar
If you're going to put the switch on the center console you can just tap the neutral safety for your kill switch.
Old Mar 27, 2018 | 06:09 AM
Thanks. That is what I will grab the neutral safety switch wire. Most likely hide the switch under the dash somewhere.
TexaStang
Jun 1, 2021 02:27 PM
Emma
Jul 9, 2016 07:09 PM
KenCarroll
Jul 7, 2014 08:23 PM
jim010
05-09 Interior and Audio Mods
Dec 1, 2008 03:16 PM
Knight Rider
Apr 17, 2007 11:47 PM
