Sync bluetooth connection problem
Old Aug 18, 2016 | 11:48 AM
glo106's Avatar
Over the weekend while driving, Sync randomly dropped connection with my phone via bluetooth. This has happened in the past but previously after a minute or a couple, it'll reconnect. This time, it has not been able to reconnect with my phone. I have tried deleting all bluetooth devices and doing a master reset several times, to no avail.
Sync no longer shows up on my phone as a bluetooth device available to connect to. This is definitely not the phone's issue as Sync doesn't show up in any other phone I've tried to connect either. When I select "Add bluetooth device" on Sync and then it tells me to hit Ok to "Find Sync," I repeatedly get the message that "pairing failed." I have a bad feeling that the bluetooth in the car is caput.
Anyone else experience this problem before?
Old Aug 18, 2016 | 12:59 PM
SpectreH's Avatar
Pull the Sync fuse (15A, fuse #3) in the interior fuse panel to reset the sync system.
Old Aug 18, 2016 | 01:01 PM
kylerohde's Avatar
Nope, haven't had that happen. Disconnecting the negative battery wire of your car for 15 minutes would reset the system to see if that helps, perhaps.
Old Aug 18, 2016 | 01:11 PM
Coyote5-0's Avatar
Is this considered a "master reset"?
Old Aug 18, 2016 | 01:15 PM
SpectreH's Avatar
No, my car lost it's BT connection and could not find the phone. The Master Reset did not work. Pulling the fuse for 5 seconds fixed it.
Old Aug 18, 2016 | 02:04 PM
FordIVTteam's Avatar
Ford In-Vehicle Technology Rep
Hey glo106,
Have you checked to see if there is a software update available?
Cara
Old Aug 18, 2016 | 02:17 PM
glo106's Avatar
Thanks, guys. I will try the fuse pull after I get home from work. I did something similar once before when Sync was having Pandora problems, and I am loath to do it again because opening up that panel was a bit of a pain.
Originally Posted by FordIVTteam
Hey glo106,
Cara
Yup, was next thing I looked for after master resetting didn't work.
Old Aug 18, 2016 | 02:48 PM
Bummer! More than likely you'll need to go to the dealer for a more hands on approach. Keep me in the loop!
Cara
Old Aug 18, 2016 | 09:16 PM
glo106's Avatar
The fuse pull worked! Back in business again. Hopefully it will be a long while before I have to do this again.
Old Aug 19, 2016 | 05:24 AM
SpectreH's Avatar
I've owned my '13 since June of 2012. The first time I had to do the fuse pull was about a month ago. Then I had to do it again 3 days later. Since then, all has been well.
Old Aug 19, 2016 | 06:06 AM
Coyote5-0's Avatar
someone should make a fuse switch relocation kit for this problem haha
Old Aug 19, 2016 | 06:23 AM
SpectreH's Avatar
I seem to recall some folks may have spliced into the wiring and done just that at some point. I'm too lazy to search for it though, and I do not recall them posting detailed instructions on how they did it.
Ideally, it you could feed the fuse from a keyed source instead of an always on source, you'd be good to go.
Old Aug 19, 2016 | 04:56 PM
glo106's Avatar
Maybe this is gonna be an annual summer thing for me. The last time I did the fuse pull was last summer.
Old Aug 20, 2016 | 09:26 AM
maverick1125's Avatar
I used to have problems with my cell syncing Pandora with my car. I used to do the pull the fuse trick and that would work for about a month. Then I thought maybe it was my cell. I had an antivirus app on my cell. I uninstalled the app and now I haven't had any problems at all in six months. Instead of thinking it's always the car causing the problem look to see if it might be an app on your cell blocking it from connecting.
Old Mar 11, 2020 | 05:52 PM
Wajira's Avatar
Yes. The same thing happened to my 2015 Mustang ecoboost. Hold the power button and Next button together for 3 seconds. Screen will say SYNC reset transmitted. Fixes the issue instant. Credit to this guy:
Old Jul 9, 2021 | 12:18 PM
Fbautista001's Avatar
Permanent solution to the Sync Bluetooth problem?
Has anyone found a permanent solution to the Sync Bluetooth connection issue? I tried too many times removing the fuse but it not always work and it helps with the phone calls only, not with playing music from my phone. I can’t play music from my phone vía Bluetooth nor USB connector.
Old Oct 9, 2023 | 04:59 PM
05stangkc's Avatar
Sync Info!
https://themustangsource.com/forums/...3/#post7074245
Mgb,
KC
Rog13GTCS
Oct 13, 2017 11:31 AM
Azrael
Sep 21, 2015 05:30 AM
Rando
Dec 4, 2014 02:42 PM
Zathu
May 24, 2012 09:57 PM
David Young
Apr 22, 2011 09:10 PM
