Removing Stock Rear Spoiler?
Take fishing line or weed eater string and work it underneath the spoiler. Use a sawing motion to cut through the 3M tape.
Pull the spoiler off and clean the surface very well. Goo gone works great to remove the residue.
You can also use an exacto knife to cut the tape if your careful.
The Fishing line trick is a definite must! Also pick a warm day so your not taking chunks of paint up too, and buy a trim removal set that's really soft nylon plastic, and a heat gun. Take your time and it'll be off before you know it.
Fishing line will ONLY help on the outside... there are screw studs that will block it from going down the entire spoiler...
I ended up leaving mine in the sun for a bit, and then pushing UP on the bottom side of the spoiler.
m05fastbackGT (10/1/22)
I usually only Revive a Thread when I Catch a GUEST reading it. I like to Let them Know I see Them LURKING!
I could Not Resist the ACME SPOILER STRING Entry, Course you Gotta Be Long o Tooth to Get the Joke! I fought a Spoiler Remove Back in the Day Before I Found Out About the String. Not Fun!
KC
KC
m05fastbackGT (9/29/22)
05stangkc (9/29/22)
