Removing Stock Rear Spoiler?
Old Apr 23, 2011 | 09:06 AM
RedCandy5.0's Avatar
How did you guys remove your stock rear spoiler? I took out the 4 screws but i can not get the thing off. Any secrets?
Old Apr 23, 2011 | 09:19 AM
S197 GT's Avatar
3rd Times A Charm
Take fishing line or weed eater string and work it underneath the spoiler. Use a sawing motion to cut through the 3M tape.
Pull the spoiler off and clean the surface very well. Goo gone works great to remove the residue.
You can also use an exacto knife to cut the tape if your careful.
Old Apr 23, 2011 | 09:35 AM
karman's Avatar
Just out of curiousity
What spoiler are you putting on?
Old Apr 23, 2011 | 10:05 AM
Overboost's Avatar
A little heat helps as well. A hair dryer or heat gun, or even letting it sit in the sun before trying to remove it should let the adhesive release easier.
alcarames's Avatar
The Fishing line trick is a definite must! Also pick a warm day so your not taking chunks of paint up too, and buy a trim removal set that's really soft nylon plastic, and a heat gun. Take your time and it'll be off before you know it.
Old Apr 23, 2011 | 02:05 PM
chutoyy's Avatar
Fishing line will ONLY help on the outside... there are screw studs that will block it from going down the entire spoiler...
I ended up leaving mine in the sun for a bit, and then pushing UP on the bottom side of the spoiler.
Old Apr 23, 2011 | 02:06 PM
dmhines's Avatar
Comes off pretty easy when hot. Let sit in son for a while and the heat gun on bottom side. Pull up with steady force and the tape will begin releasing.
Old Apr 23, 2011 | 03:00 PM
houtex's Avatar
Originally Posted by dmhines
Let sit in son for a while...
Sounds a little painful for the poor boy.
/ok, ok, I'm leaving... sheesh, I's just playin'...
Old Apr 23, 2011 | 07:07 PM
montreal ponies's Avatar
I can see this coming a mile ahead....have someone hold the spoiler while you're doing the nylon string thing ! Just sayin' !
Old Apr 23, 2011 | 08:28 PM
shadowstang03gt's Avatar
pay a body shop $100 lol
Old Sep 27, 2022 | 08:42 PM
05stangkc's Avatar
Sure Had a Lot More Humor in the Posts Back in the Day!
I use Acme Roadrunner Spoiler String to Remove My Spoilers!
Beep Beep!
KC
Old Sep 28, 2022 | 01:03 PM
m05fastbackGT's Avatar
Removing a spoiler isn't really that complicated at all lol.
Old Sep 28, 2022 | 02:07 PM
05stangkc's Avatar
I usually only Revive a Thread when I Catch a GUEST reading it. I like to Let them Know I see Them LURKING!
I could Not Resist the ACME SPOILER STRING Entry, Course you Gotta Be Long o Tooth to Get the Joke! I fought a Spoiler Remove Back in the Day Before I Found Out About the String. Not Fun!
KC
Old Sep 29, 2022 | 05:31 PM
Fishing line is even better over string
Old Sep 29, 2022 | 05:40 PM
05stangkc's Avatar
But ACME String is is MAGIC!
COYOTE APPROVED & ROADRUNNER TESTED!
BEEP BEEP!
Old Sep 29, 2022 | 06:12 PM
Wile E. Coyote - Super Genius
Old Sep 30, 2022 | 02:45 AM
Old Dec 23, 2022 | 02:31 PM
Anytime and welcome aboard!
boss 302
Apr 14, 2007 05:51 AM
DarkProphet
05-09 Exterior Modifications
14
Dec 28, 2006 05:41 AM
pittperson
Aug 1, 2006 08:42 AM
rony1976
23
Feb 13, 2006 10:08 AM
WarBird69
1994-2004 V-6
Dec 20, 2005 10:34 AM
