Oil separators and fate...(JLT vs Bob's vs Moroso)
#122
++ on that. I've had my GTCS for over 6 months and intermittently I have had (on stock) what I swear is "pinging" (actually coming from the passenger side). With the recently installed ProCal (LOVE it BTW), I made sure I included an oil separator (up to now I have NEVER had one or even knew what the importance was). I ended up with the Moroso, looks good (do agree with the slightly cheap looking bracket though).
SO far, after 2 weeks, I have NOT heard any more pinging.
Finally ended up registering just to chime in on this (been lurking for months). Looking forward to alot of great info and experience here.
#128
I ended up reinstalling my PVC Valve. Motor developed a small leak. Got the dealer to shampoo the bottom end and advised me get rid of my breather filter and just use the PVC valve and see if it stops leaking.
They didn't say it was because it was the breather. But they also didn't rule it out.
#129
#130
#131
Perhaps I'm either missing something or Ford must had changed the design after they discontinued the 3 valve 4.6L in favor of the current 5.0L Coyote 4 valve
#132
Question for you Joe ! How do you uninstall and then reinstall your PCV valve ? From my understanding the PCV valves are integrated into the cam covers and can only be removed by first uninstalling the cam cover and then having to use a small cutting tool to cut into the tube which houses the PCV valve in order to extract it..
it was just a matter of removing the breather filter and clipping the PCV hose back on.
#133
Therefore unless you disable the PCV system altogether ? it is not recommended to run an open breather setup, as doing so will create a vacuum leak..
The problem with some of the cheaper catch cans, is their poor design which still allow oil vapors to get past the PCV connectors and into the upper intake.. The $100.00 and up catch cans on the other hand, have a much better design that stop oil vapors from getting past the PCV connectors and into the upper intake that include stainless steel filter rings along with stainless steel filter mesh material to help trap crankcase oil more efficiently..
With that being said, I would highly recommend the following catch cans..
1) Bob's oil separator
2) UPR 4 chamber catch can
3) Moroso oil catch can
#134
I was chastised quite awhile back on a thread warning folks not to remove their PCV valves. It is simple logic that a crankcase will build pressure unless properly vented. Guess I was right!
#135
Brandon ! With the PCV system intact, your upper intake vacuum will still vent the crankcase under normal driving conditions while at part throttle..
Vacuum only closes during full throttle and then will re-open whenever crankcase pressure builds up.. But just to be on the safe side, I went ahead and purchased the CFM breather kit which is really a pressure relief valve designed to be fully compatible with the factory PCV system which stay's fully closed under normal driving conditions while still under vacuum, but will then open when at full throttle in order to fully vent the crankcase and relieve any unwanted pressure build up..
Anyway just another option you may want to consider looking into
#136
Putting a breather on the driver's side without removing the actual PCV valve does nothing. The valve will stay closed and nothing will ever come out of it. If you remove the valve and run an oil cap breather there will now be 3 outlets for the crankcase and you will have a lot less build up of oil saturating the filters.
To remove the actual PCV valve you do have to take off the cam cover. Then you cut and pull back on the baffle to expose the little pipe where the valve is. I cut that open with a dremel and removed the little valve and then just folded the baffle back into place. I don't have any pics but it's simple. I have a set of stock covers sitting around in my garage somewhere if you really need some pics on what I'm talking about.
#137
Knew I should not have commented on this thread. Truly not looking for an argument. But there is nothing anyone can say to convince me that removing a PCV valve is a good idea. I have a JLT Separator because I agree that oil in the intake is bad. But removing the PCV to prevent this is a poor choice in my opinion.
#138
Perhaps you should take the time and read my response to your last post once again and hopefully then you'll realize I share the very same opinions as you do, as I also use an oil separator !
#139
Ha Ha!... My Bad. I thought you must have made a typo... I could not figure out why you were disagreeing with me and making points to my case. It was late... And I was all full of Nyquil fighting off a cold... No hard feelings I hope...
#140
All I was trying to point out to you, is under normal driving conditions at part throttle your upper intake vacuum will properly evacuate and vent the crankcase with the factory PCV system fully intact..
The only time your intake valve shuts off vacuum, is during wide open throttle or while under boost with FI.. However when crankcase pressure builds up, the intake valve is designed to open back up in order to relieve the pressure..
As I mentioned earlier, I added the CFM billet valve cover breather kit which actually functions as a one way check valve that's fully compatible with the factory PCV system and is designed to work just as a regular oil cap during normal driving conditions in which the pressure relief valve stays fully closed while under vacuum but when driving at wide open throttle, the relief valve will then open in order to relieve pressure and vent the crankcase more efficiently.. However as I said, the pressure relief valve is only a one way check valve to vent the crankcase under pressure, but will not allow airflow to enter back in like a regular breather kit would do..
At any rate, I decided to add the CFM kit with my Bob's catch can just for added protection/insurance.. I also decided to go this route, as I do not recommend disabling the factory PCV system for street performance applications and especially not for those used as daily drivers..
Anyhow I hope this clarifies any misunderstandings from my earlier post ? and there are also no hard feelings whatsoever Brandon, as it was nothing more than just a misinterpretation on both our parts
In the meantime, hope you're feeling better soon and Happy Holidays to both you and your family..
-Rocky
