Leaking Differential and Rusty Shock?
Old Dec 4, 2014 | 03:07 PM
dave07's Avatar
Decided to look under my car today and check things out. Noticed some fluid around the back of the differential. Wth? Why is it leaking there. I did have the breather leak and that was fixed awhile ago but this seems to be a new leak.
What's up with the shock? Is that normal?
Old Dec 4, 2014 | 03:33 PM
dmichaels's Avatar
My rear shocks seem to do the same. Bit of rubbing not sure why
Regarding the diff, was it worked on? Looks like the sealing may have started to fail allowing a bit of leakage.
Old Dec 4, 2014 | 03:39 PM
dave07's Avatar
The differential wasn't worked on. The TSB for the breather tube was applied.
I'm not sure whats up with the shock...
Old Dec 4, 2014 | 08:22 PM
csrMark's Avatar
My 2012 has 10,000 km's on it. One rear shock is leaking and when I took it to get Krown rust sprayed the guy said there is a lot of rust under the car. Ford needs to paint/coat parts before putting them on the car..
Old Dec 6, 2014 | 02:26 PM
Blown CS's Avatar
Looks like your pinion seal needs to be replaced. Had mine replaced at 15k miles.
Old Dec 6, 2014 | 09:12 PM
dave07's Avatar
Did they say what caused it?
Old Dec 7, 2014 | 08:54 AM
Blown CS's Avatar
No they didn't and mine started out like yours and a month or so later I started to get a couple of drops on the garage floor.
It only took them an hour to complete the job under warranty.
Old Dec 8, 2014 | 05:16 PM
JohnnyMustang2's Avatar
My 2013 had plenty of rust on the underparts for a car that was 2 months old. I think its the low quality foreign metal used.
Old Dec 8, 2014 | 06:22 PM
dave07's Avatar
Yea I don't care about the rusty axle and diff cover. More concerned with the shock. It looks like the metal is rubbing.
Old Dec 8, 2014 | 06:44 PM
RIBS's Avatar
My v6 is doing the same rust on the shock. It's really nothing to worry about. The dust and moisture cover is not centered and is rubbing the paint off the main body of the shock. It really just looks bad. You might be able to grab it and re center iit over the shock and clean it up and hit it with black spray paint. I would get that bearing or seal that is leaking fixed asap though!
Rando
Aug 25, 2021 11:12 AM
Gill5oh
Oct 6, 2017 10:50 PM
ricky1728
Feb 11, 2016 07:25 PM
09-gt/cs
Oct 15, 2015 10:03 AM
GeoWett
Sep 30, 2015 06:40 AM
