info on oil change DIYs and oil filter choices for 2011+ 5.0s
#62
Originally Posted by texastboneking
I.e. you put a 10w-50 oil in a 5w-20 engine and your cams freeze up in the heads due to lack of oil. they will void the warranty because your oil was too thick for the pump to get it to the cams.
I plan on doing 5W-30 Amsoil myself with a Motorcraft 500 filter.
#63
The 5 w 20 weight oil was recommended by Ford for other reasons than what the engine actually needs. Either weight of 5 w 30 or 5 w 20 will be fine. I have never heard of an engine being damaged because of using 5 w 30 oil complete nonsense and rubbish.
#64
Bear Eats King...
Bear ****s Bone
Bear ****s Bone
#65
Bear Eats King...
Bear ****s Bone
Bear ****s Bone
Originally Posted by flySWA737
Last I heard the Boss 302s engines are recommended to run 5W-50 weight oils. I don't think a heavy weight oil can really harm the cams of these engines but correct me if I'm misunderstanding something. I understand the Boss revs higher and doesn't have oil squirters but I don't remember reading much about the cams varying much from the standard coyote. Have read on bobistheoilguy that 5.0s in Australia are recommended from Ford with 5w-30.
#66
Bear Eats King...
Bear ****s Bone
Bear ****s Bone
#67
Funny. I didn't know you were on the Ford team when they designed the engines. Or are you believing whatever you read on the internet? I could say Ford only uses gas in the mustang because its cheaper than diesel. But that wouldn't be right. Just like you comment here.
#68
#69
I have a jug of Mobil 1 right here.. says "Fully Synthetic" on it.
Mobil 1 still says it's "Full Synthetic"
http://www.mobiloil.com/USA-English/...l_1_5W-20.aspx
"Mobil 1 5W-20 is an advanced full synthetic motor oil designed to provide exceptional wear protection, cleaning power and overall performance."
If you can prove it, you have a good lawsuit potential on your hands.
Extended performance appears to simply have an additive package more suitable for extended drain periods.
What I keep finding across the web is rumor. And various 'reasons' why mobil 1 is no longer 'fully synthetic' or it still is...
Ultimately I suppose the confusion comes down to the idea of how much base III vs. IV vs. V is used. The primary basis of this appears to be rumor and guess work and what changes in formulation may or may not mean. In the end though it really doesn't matter how much of each is used, but the performance of the end result which makes these rumors even more worthless.
Rumor says Mobil 1 is mostly base III, guess work is saying it's mostly IV from what I read.... Anyway it seems there is tons of people guessing online with no real facts either way arguing about an essentially meaningless difference.
#70
#71
Full synthetic and 100% synthetic are different things.
Castrol won a lawsuit a few years ago that allowed them to call their oils with up to a certain percent of group 3 base stock full synthetic. Mobile one did the same to save some money.
Only oils from group 4 and 5 base stocks are actually 100% full synthetic.
#73
Don't hurt yourself and let me answer that for you. That's because here in the United States there is a thing called cafe requirements. The 5 w 20 oil is claimed for optimal fuel efficiency and wear to comply with cafe. All nonsense. By all means use 5W20 oil if you feel better but me, im sticking with 5W30 for better engine protection.
#74
Bear Eats King...
Bear ****s Bone
Bear ****s Bone
Originally Posted by RadioFr33Europe
So, if you use the same weight, but a different, respectable brand, Ford can void your warranty? Or just about using a different weight?
Also a big role in this is the dealer you go to. Most dealers probably won't give a ****. But some dealers are picky.
#75
Bear Eats King...
Bear ****s Bone
Bear ****s Bone
Well Since you feel that I'm so off on my statement please enlighten me to the reason that 5 w 20 here in the united states is recommended by Ford. Yet the very same ford automobiles with the very same automobile engines sold in Europe use a 5w 30 weight oil. Ford does not recommend 5w 20 oil for their automobiles sold in Europe which is the same automobiles that sells in the United States. Now if 5 w 20 oil was so much better then why isn't Ford using it in the cars in Europe. Maybe its just me but im lost. Ford x in US needs to use 5W 20 oil. Same Ford X in Europe needs 5W 30 oil.
Like I said, you believe what you read on the internet. Cafe does play a role but that isn't what makes Ford decide on what oil to use. All that cafe crap makes a good story but no one has proved that cafe is the reason Ford chose 5w20.
#76
Take the climate of Europe, and the general climate of the US. They make the decision on oil weight that will perform best in each climate. Obviously the US generally has a cooler climate (minus the few hot states) and they decide on a thinner oil. Europe's overall climate is a little warmer so they went with a slightly heavier oil.
For as hard driving and heated those big V8 engines get from their drivers, 5w30 is the way to go. What do you harm by going to a 5w30 weight if you live in a area that has all four seasons?
#77
Bear Eats King...
Bear ****s Bone
Bear ****s Bone
Im sure that putting 5W30 oil in the mustang will not hurt it one bit.
What do you harm by going to a 5w30 weight if you live in a area that has all four seasons.
#78
never said it would. Just stated Ford could void warantee if the felt like it.
In all honesty you won't hurt anything most likely. But the argument is if Ford will void the warantee over it. And the answer is yes, if they want.
#79
Bear Eats King...
Bear ****s Bone
Bear ****s Bone
The extended waranty is not near as stringent as the factory warranty. And Ford doesn't send your oil off to get the weight of the oil measured. If you simply say you used 5w20 the dealer wouldn't know the difference.
#80
