Notices
Sponsored By:
Sponsored By:
the good old argument about oil change
Old 1/29/14, 01:59 PM
  #81
2011 Kona Blue's Avatar
Originally Posted by Bucko
Yes, should be fine, but here lies the issue; why is Ford stating one oil for an engine that is refered to as a track pack, and another oil in an engine that is not? I'm aware that the Boss has some additional goodies to give it a 'go faster' capability. Is it because the Boss 5.0 has forged internals? Are these forged parts requiring this difference in oil viscosity? Forged internals have different tolorences "metal to metal?
I'm guessing the Boss does not factor into any CAFE statistics for fuel economy, so I'm rulling that out.
Bucko am I making any sense here bro. Forged internal parts or not for a Boss the engine is still the same and has tight engine specs. Those tight specs require thinner oil to lubricate those parts according to many which is the argument and reason 5W 20 is needed. So if that's the case why would someone use 5W 50 oil weight on its tight spec engine. Doesn't make any sense too me..
2011 Kona Blue is offline
Old 1/29/14, 02:01 PM
  #82
Not quite the same engine...the Boss's engine has forged internals. Could this be the reason it requires a different viscosity?
The base 5.0 and 5.0 with trac pack are the same engines so why the different oil weights if 5W 20 is better?
Old 1/29/14, 02:05 PM
  #83
Thamac15's Avatar
Just put Gatorade in.
Thamac15 is offline
Old 1/29/14, 02:39 PM
  #84
I tried that already.
  #85
Bucko's Avatar
So, we have three variables? The Boss, the 5.0 track pack, and the 5.0 GT?
The Boss specifies 5w-50, the track pack 5.0 specifies 5w-50, and the GT 5.0 specifies 5w-20?
Do I have this right?
Bucko is offline
Old 1/29/14, 03:02 PM
  #86
That's is my understanding yes. Three variables
Boss 5W 50
5.0. 5W 20
5.0 with trac pack. 5W 50
Now my understanding the Boss engine is the same 302 engine as the 5.0's with a bit more HP, torque and some forged parts but same tight spec engine
Old 1/29/14, 03:07 PM
  #87
Bocefus's Avatar
I use chuck Norris urine as my motor oil.
Bocefus is offline
Old 1/29/14, 03:11 PM
  #88
Better than Chuck E Cheeses urine.
Old 1/29/14, 03:12 PM
  #89
Bocefus's Avatar
rat bast@rd
Bocefus is offline
Old 1/29/14, 04:19 PM
  #90
rat bast@rd
Lmao
Old 1/29/14, 04:33 PM
  #91
88lx50's Avatar
Track pack is same engine as regular GT aside from an oil cooler and Ford specs 5W50. It must have something to do with intended uses of the car.
88lx50 is offline
Old 1/29/14, 05:01 PM
  #92
GrnT's Avatar
It's just Oil not rocket science.
GrnT is offline
Old 1/29/14, 05:06 PM
  #93
typesredline's Avatar
Doing research on the internet in no different than doing research in a library. What's the difference in obtaining information? The library has books that people can touch that have printed material that states either facts or opinions about a topic and subject. The internet has the same or very similar documents as the library only in electronic format which are written materials that state facts and opinions. Now granted I'm not saying there isn't a lot of bull and garbage out on the web but there is also tons of good solid articles and posts that are informative and educational. So here's the million dollar question. Where does someone find good factual solid information that shows 5W20 oil is better or 5W30 oil is better too use? Here is the part that really confuses me so perhaps your wisdom can explain! Person A owns a 2014 5.0 and the oil cap reads 5W 20 oil. Person B owns 2014 5.0 with trac pack option yet Ford recommends 5W 50 weight. Ford engineers state that 5W 20 weight works better because it can lubricate areas of today's tight spec engines in areas better than a thicker oil say 5W 30. A base 5.0 and 5.0 with trac pack have the identical tight spec engine yet the one with the trac pack calls for 5W50. How can 5W 50 oil possibly properly lubricate two identical same engines when Ford calls for 5W 20 on the one engine. That doesn't make sense too me. So, if a 5.0 gets 5W 50 oil then why couldn't someone safely use 5W30 oil in a car that calls for 5W 20 oil and also uses 5W 50 oil? I'm lost on that?
Wait. You know I'm on your side right? Lol
typesredline is offline
Old 1/29/14, 05:08 PM
  #94
Heck yeah. What the ***** do I know. Im more confused now than I first started. Frig it, im using snake oil from now on. Lmao
Old 1/29/14, 05:09 PM
  #95
Yes, should be fine, but here lies the issue; why is Ford stating one oil for an engine that is refered to as a track pack, and another oil in an engine that is not? I'm aware that the Boss has some additional goodies to give it a 'go faster' capability. Is it because the Boss 5.0 has forged internals? Are these forged parts requiring this difference in oil viscosity? Forged internals have different tolorences "metal to metal? I'm guessing the Boss does not factor into any CAFE statistics for fuel economy, so I'm rulling that out.
Even though the materials are made differently, the tolerances still have to be in spec. But remove the boss from the equation entirely since it is slightly different.
The tp gt and regular gt have identical motors down to every part number (except for the radiator and oil cooler etc). Yet they call for different oils.
Old 1/29/14, 05:16 PM
  #96
I think he was referring to the tp gt which uses the same exact engine as the regular gt yet call for two different oil weights. The boss which is slightly different in components (but same spec) also calls for this heavier weight.
Old 1/29/14, 05:25 PM
  #97
yugoboss's Avatar
These oil threads should be banned immediately. Buy a quality oil change it regularly, and put in the grade the manufacturer recommends.
yugoboss is offline
Old 1/29/14, 05:28 PM
  #98
Exactly my point but why. Why does the manufacturer give two different oil weight recommendations for the same exact car and engine. Yet Ford claims 5W20 provides better lubrication and engine wear because of the tight engine specs and it gets down to parts where thicker oil can't get too. Then at the same breath recommend 5W 50 oil for that same car, same engine with upgraded suspension parts. That just goes too show that 5W 30 is not going too hurt anything according too Ford.
I think the bottom line is that Ford hasn't disclosed the real reasons because they can't have the liability on them for people doing stupid stuff. Same as the new LT1 motor even though went through massive testing running at redline while on a tilt-a-wirl, Chevy yet says it's not ok to race it.
The tolerance thing is a PR cover for liability.
The real reason is that Ford has to have their regular line up if vehicles average a certain mpg based on volume sold. They sell a ton of gt's. The 5-20 in testing could have had no adverse affects in motor life yet extended mpg by one or two. That is important for their averages. The boss is limited run (and the tp is limited too) so having a heavier oil is not going to hurt averages. BUT they don't want people coming in with blown motors bc they were run hard on the track with a 20 weight oil. Then they'd have the argument of "why'd you sell me a 'track pack' but it's not meant to be tracked?" Law suit. So they put thicker oil in it.
It's up to is at that point to say what's more important. Mpgs or protection. If you granny drive it maybe you can run 20 weight and have both. I'd rather have protection since I didn't buy a v8 for mpgs anyway.
On a side note. Heaven forgive me for implying that Ford being a business to make money might have made a statement that wasn't completely true. I will sing 10 mustang sallys now.
Old 1/29/14, 05:37 PM
  #99
It's not better. It's for a different application. I met a 67 yr old women that bought a 13 gt because her recently deceased husband had always wanted one. Do you think she drives hard. I doubt it. It was a auto too so probably NEVER saw the redline. Yet I buy a 13 gt manual and track it monthly. Vs a tp or boss owner are manual only and geared for someone who will beat on it.
What they are saying is that 20 is good for the diverse group that will buy a gt. 50 is for driving hard. I run 30 because I don't want to hesitate mashing it if I feel like I've done it too much recently and the 20 might not handle it. I'm more confident running 30.
Old 1/29/14, 05:41 PM
  #100
This thread has allowed me to vocalize my reasoning and see other views. Plus having to think of witty ways to get back at the jerks on here. I see it clearer than ever now.
Quick Reply: the good old argument about oil change
