Exhaust + Air Filter = 11.20 @120.5MPH
Old Nov 10, 2011 | 02:47 PM
dafreeze's Avatar
I'm impressed, nice driving.
Originally Posted by blackgt87
I really don't want to get into another pissing match...
Not the impression I've gotten. Read your tune complaing thread and have obviously noted your signature. When do you graduate?
Old Nov 10, 2011 | 03:04 PM
Shaun@AED's Avatar
Originally Posted by AlsCobra
Man! Haters gonna hate. Good times op. I'm guessing that you are trapping at the top of 4th gear? Mph means nothing in a drag race. ET racer will beat a much stronger car. It already doesn't sound like a friendly race. Are y'all putting up any cash on the race?
Yes, 4th gear @ 7250RPM.
Old Nov 10, 2011 | 03:17 PM
blackgt87's Avatar
Old Nov 10, 2011 | 03:26 PM
blackgt87's Avatar
Whats your rear tire size?
All I'm saying is I went 119.2 mph (on the rev limiter for 50 feet) on 93 octane and a JLT and a lethal off road x pipe, with a mail order Bama tune with a DA of 713 feet. No ported intake manifold, no E85, no 200 lb weight reduction, no aluminum driveshaft, no light *** 15" race wheels.
I'm not hating on the the ET, hell I'm not even hating on Shaun, I'm just saying the mph isn't impressive for all that. Not when I look at mine anyway. That's a great drag setup driven really well, not necessarily a spectacular tune.
I got money says he puts that stock intake manifold into the 10's NA
Old Nov 10, 2011 | 03:35 PM
AlsCobra's Avatar
A Man Just Needs Some....
Dang that's screaming. I am also curious about tire size. Wondering if a taller rear tire will give you any gains. And also have you tried shifting earlier and using fifth. Just curious.
Old Nov 10, 2011 | 04:08 PM
kjacobson351's Avatar
Originally Posted by kjacobson351
Grats! These new 5.0's continue to impress me.
Lol ok the 11.2 makes more sense now. Still though that is awesome!
Old Nov 10, 2011 | 04:31 PM
Shaun@AED's Avatar
You are correct Bill, nothing spectacular in the tune.
What is impressive is what Ford gave us in the Coyote/MT82/6R80. All I've been doing in the tune is removing parameters that don't allow full power to get to the ground. Nothing special about that. Hell, it's in the Ford Racing Crate Motor calibrations.
Aside from the tune I've focused on maximizing each bolt-on to it's full potential before moving on to the next modification. Nothing special about that either.
The tires are Hosier 28x10.5 slicks.
And I plan on hitting 10's with the stock intake manifold, stock heads/cams/headers. I do need to find a bit more power and a bit more hook somehow.
FWIW since I'm going thru the traps in 4th well above peak power for a stock intake, 1/4 MPH will be low compared to the 1/8th. The slip posted is my best 1/8th MPH to date at 98. By contrast a few C6 Z06's were trapping 99 and 126 last night.
Old Nov 10, 2011 | 04:42 PM
5 DOT 0's Avatar
Impressive. I've read good things about AED.
Old Nov 10, 2011 | 06:45 PM
going for broke's Avatar
Normally when you improve your short times you will decrease mph on the big end. Mph means nothing on a drag strip. It's all about the et.
Sounds like you went 119 on stock sized tires not drag radials. Even a slight circumference difference would be enough to cross traps without banging the limiter.
Great times Shaun!!
Old Nov 10, 2011 | 08:32 PM
blackgt87's Avatar
Yeah he's right about that, 98 is BOOKING for the 1/8. I went similar mph but only went about 93 in the 1/8.
My buddy has a 240 that trapped 129 and went 98 in the 1/8 the same time I was at the track.
Great times Shaun!!
Mph is usually a good indicator of power to weight ratio unless its a turbo car that spins. I was referring to the amount of power the car makes, which like Shaun even said is not out of the ordinary.
I don't know why you're saying stock sized tires not drag radials. They were drag radials and my 60' was 1.60. I have tune my limiter isn't stock, I also crossed the traps above 7300 rpm.
Old Nov 11, 2011 | 08:49 AM
My bad on the drag radials.
Old Nov 11, 2011 | 09:19 AM
SteedaGus's Avatar
Great times Shaun!!
Thats not necessarily true, trap speed can be an indicator of overall power, and how much you pull between the 1/8th and the end can tell you a lot as well, or confirm things.
I Shaun's case he knows he is well past peak power through the traps in 4th based on his dyno's, and the comparative data from the drag strip proves it when compared to the ZO6's. The ZO6's are pulling 27mph between the 1/8th and the end, he's only getting around 23 because he is not at an optimal RPM range for power.
Back in my street racing days (ssshhh) if I had access to someone's time slip I could use this kind of data, among other things do decide if I wanted to run them from a dig or from a roll... and it worked very well for me
Old Nov 11, 2011 | 10:57 AM
blackgt87's Avatar
THIS
NC14GT
Feb 20, 2023 09:42 AM
dblhelx
Oct 6, 2015 08:08 PM
mustangsally_
Sep 18, 2015 05:35 AM
samjluck
Sep 17, 2015 10:24 PM
TripleBlack14
Sep 17, 2015 07:48 AM
