TIGHT POSI
#61
Administrator, Shop Manual PDF Poster, Parts Locator & Spam Bot Eliminator!!
Received 2,748 Likes
Still having Members with this Issue!
BUMP TO INFORM!
BUMP TO INFORM!
#63
Refresh For Newbies!
#65
bump!
#66
A Noisy Posi is Not a Bad Thing! It means it is Working!
KC
KC
#68
Good advice KC but what did you mean by "less material" on the clutch plates?
Be aware that the carbon fiber clutch plates have less material, and these are OEM-equipped on 03-04 Cobras, 05-up GTs, and the 07-up GT500. These are supposedly more effective than the standard clutch plates (which have more material) that have been used since 1986.
#69
Think of a New Set of Brake Shoes Vs a Worn Set. Less Material
FYI My Shelby Has a Very Noisy Posi! That means It's Working!
KC
KC
#71
http://forums.bradbarnett.net/showth...587#post872587
Carbon Fiber vs standard clutches.
I have never heard of Ford using new replacement clutch packs that are "worn out".
My 07 GT has a very quiet Traction-Lok and I never had to add any friction modifier.
#72
NOt worn out Just Thinner.
#73
If you have the Rubbing Sound when making a Tight Turn I would Say Yes. Consider it an Aggressive Posi. If you Have Rear Axle Noises under other Driving Conditions it could be somthing else.
#74
My Shelby Had This Issue and a Bottle of Additive Fixed the Noise ASAP!
