Missing Issues
Old Dec 28, 2012 | 05:36 AM
2_CW_2's Avatar
Missing Issues
GT is still missing after fresh tune wit spark plug, accel super coil packs, fuel filter, and air filter!!!! Really need help
Old Dec 28, 2012 | 07:08 PM
bluethunderhorse's Avatar
Just off the top of my head but throttle position sensor, mass air, crank position sensor, and the ecm can cause skipping
Old Dec 29, 2012 | 07:15 AM
skunk21's Avatar
answer I gave the other post:
check codes and see what is going on or what cylinder is doing it. you could have a power issue to a coil, excessive carbon build up, faulty injector, etc. also you may want to try and clean the maf.
Old Jan 2, 2013 | 09:49 PM
fastfive_ogt's Avatar
I would check it out with an IDS scanner. Do a power balance test and cylinder contribution test. You need to narrow it down to what cylinder is causing the misfire. Then you can determine if the problem is base engine or fuel/spark related or possibly even timing.
Old Jan 3, 2013 | 09:27 AM
2_CW_2's Avatar
Found out that it's my MAF sensor is goin bad thanks for da help fella's
Old Jan 3, 2013 | 10:05 AM
skunk21's Avatar
Road_Runner
Sep 2, 2024 04:46 PM
kponypower
Jun 17, 2020 07:17 AM
09-gt/cs
Oct 15, 2015 10:03 AM
Antigini-GT/CS
Oct 5, 2015 09:43 AM
