Amp Sub enclosure
Old Jul 8, 2007 | 01:36 PM
biscuit676869's Avatar
Originally Posted by jcthorne
You can also buy that enclosure unloaded. Thats what I did and installed a Blaupunkt V12 sub. The low level sub signals are not present in the rear on 06 and newer cars without the S1000. You have to go to the connector near the sub amps at the driver kick panel. Power along the pasenger side is fine, there is a rubber plug through the firewall just below the batter/ac above the passenger footwell. Make sure the wire you run for power is sufficient for the amp.
So you saying use a line convert or something like SoundGate LOCB.2?
Old Jul 8, 2007 | 03:31 PM
Infinity's Avatar
You may as well use a cheap LOC since any distorion harmonics introduced will be FAR above subwoofer range. The little Scoshe one from Wal Mart works well, has adjustable input gains, and I like the screw-down inputs as opposed to wire pigtails.
Old Jul 10, 2007 | 05:46 PM
GTJeff's Avatar
What kind of sound can I expect from these subwoofers in the Scosche Enclosure. Booming Bass ?
Old Jul 10, 2007 | 07:16 PM
Infinity's Avatar
It depends on the driver of choice, but it is a 1.25 cubic foot sealed enclosure. You won't get boom from that. You CAN get solid low-end reinforcement with the ability to get loud enough to hear/feel over custom exhaust/road noise.
Old Jul 10, 2007 | 07:33 PM
GTJeff's Avatar
Actually I don't want booming bass (I'm getting old, I guess).
Loaded with the EFX 12" sub and running a Visonik V108XT Amp,
would this just enhance the Shaker 500 overall performance?
That's what I want...
Old Jul 11, 2007 | 05:48 AM
Infinity's Avatar
I've been told the EFX woofer is decent, I don't know. Only sending it 200 watts may be a bit slim, but it should make for a good enhancement. If you haven't bought it yet, get the box unloaded, and select a different woofer. At that low power, the DIYMA 12 would be awesome, and the frequency response would rock.
BigHoss
Sep 21, 2015 10:03 AM
RCooke08GT
05-09 Interior and Audio Mods
Sep 1, 2015 08:07 PM
forceflow2
'10-14 Interior and Audio
Aug 4, 2015 08:02 PM
K.A.I.N
Jul 20, 2015 06:42 AM
RRRoamer
69
Feb 21, 2006 03:58 PM
