Windage Tray kit??
Old Jun 5, 2006 | 08:30 PM
ryan1112's Avatar
Windage Tray kit??
I found this windage tray kit at rpmoutlet. Has anyone tried it? I can't imagine that it gives an extra 15 - 18 hp.
http://www.rpmoutlet.com/05gtfuelr.htm
Old Jun 5, 2006 | 08:40 PM
softbatch's Avatar
I talk to cones.
Canton is the one of the best there is, and yes those hp numbers would probably be about right.
Old Jun 5, 2006 | 08:44 PM
don_w's Avatar
Some good discussion here about that tray... start at post #18:
http://www.modularfords.com/forums/2...y-49662-2.html
Old Jun 5, 2006 | 08:45 PM
don_w's Avatar
I'm not so sure...
Old Jun 5, 2006 | 08:49 PM
ryan1112's Avatar
Do 2005+ stangs have a windage tray stock? If they do, I wonder how much better this one could be.
Old Jun 5, 2006 | 09:01 PM
ryan1112's Avatar
Thanks for the read. I see that the stock 05 does have a tray.
Old Jun 5, 2006 | 09:37 PM
don_w's Avatar
Yea, my stock one took a hit...
Old Jun 6, 2006 | 07:01 AM
ryan1112's Avatar
My God, what happened to that thing?
Old Jun 6, 2006 | 07:29 AM
169stang's Avatar
I don't believe those gains on the 3V motor. The crank isn't running thru the oil in the pan. The oil pan, stock or aftermarket, has a baffle which prevents the splashing around of the oil. The windage tray just keeps extra oil off of the crank. I'm not saying a windage tray doesn't work with this motor. I am saying that I doubt those gains with one though.
Old Jun 6, 2006 | 09:18 AM
don_w's Avatar
That's what happens when rods snap and fly around the inside of the engine.
Old Jun 6, 2006 | 08:53 PM
spyder7724's Avatar
i'm selling one on ebay if your interested. sorry no link but do a search for windage tray ford 4.6 and it should come up. i'll get another one when i build the 5.4 but i just didn't want to pull the pan now. it is better then the stock tray since the stock one doesn't return oil to the pan as well. this one has the diamond stripper stuff on it to "scrape" up the oil flinging around the crank. oh yeah it's a lot cheaper too!!!
Old Jun 6, 2006 | 09:39 PM
169stang's Avatar
Let me know if your interested in a 5.4L Ford GT block. I have a new one in the crate still for sale!
Old Jun 7, 2006 | 06:24 PM
spyder7724's Avatar
is that the aluminum block? i still have to find out what if anything is different on the 5.4 3V block.i know the 3V 4.6 has a different motor mount bolt pattern. wonder if it's the same on the 3V 5.4? anyway since i put the front suspension on and dropped a bit of weight i don't have any concerns about adding 100 lbs. or so for the factory block but aluminum sure would be nice especially if it's got the big bore sleeves then it will go out to about 370 cid with a stroker crank. with 11.5 :1 compression, good cams and headwork it should make well over 400rwhp and buttloads of torque.
Old Jun 7, 2006 | 10:30 PM
169stang's Avatar
M-6010-GT**
Original equipment for the 2005 Ford GT supercar
356-T6 aluminum casting with cast iron sleeves
90.2mm bore
Dry sump machined, can be machined for wet sump
Enhanced bulkhead and main webbing strength compared to production 4.6L aluminum block
Machined for piston oil squirters
Block modifications required for starter in non GT applications
Weight: 110lbs
Road_Runner
Sep 2, 2024 04:46 PM
09-gt/cs
Oct 15, 2015 10:03 AM
GeoWett
Sep 30, 2015 06:40 AM
MustangGTCS13
Sep 17, 2015 07:38 AM
Sep 16, 2015 06:44 PM
