Stock front sway bar/add holes 4 adj?
Has anyone added a hole or two to the factory front sway bar to get some adjustability out of it...seems there is plenty of room to add a hole..mayby two..like on aftermarket bars
gt500 bar
Is the bar a bigger diameter? all aftermarket ones seem to be 1 3/8 diameter..i'm just wondering if i could drill another hole and get some more stiffness out of it rather than buy a new one..
Anything you do to shorten the lever arm will make the bar stiffer. Maybe not as stiff as a 1/38, but stiffer. If you are doing this mod only to the front you are going to make it understeer more than it does now. You really need to tweek both ends.
rear bar
Thanks..i also have a 7/8 inch aadco rear bar in now..so iwanted to balance it a bit...rearend plants alot better..and front leans more now...
robjh22
Custom Vanity Personalized License Plates & Brackets /Delete Brackets
14
11/1/15 11:28 PM
7/30/15 06:47 AM
