Stock front sway bar/add holes 4 adj?
Old Sep 1, 2007 | 10:46 PM
Fman67's Avatar
Has anyone added a hole or two to the factory front sway bar to get some adjustability out of it...seems there is plenty of room to add a hole..mayby two..like on aftermarket bars
Old Sep 2, 2007 | 09:55 AM
classj's Avatar
I believe the front bar from the GT500 has a second hole for adjustment. I have to look downstairs later
Old Sep 3, 2007 | 12:37 PM
Fman67's Avatar
gt500 bar
Is the bar a bigger diameter? all aftermarket ones seem to be 1 3/8 diameter..i'm just wondering if i could drill another hole and get some more stiffness out of it rather than buy a new one..
Old Sep 3, 2007 | 04:52 PM
RadBOSS's Avatar
Anything you do to shorten the lever arm will make the bar stiffer. Maybe not as stiff as a 1/38, but stiffer. If you are doing this mod only to the front you are going to make it understeer more than it does now. You really need to tweek both ends.
Old Sep 3, 2007 | 07:23 PM
Fman67's Avatar
rear bar
Originally Posted by RadBOSS
Anything you do to shorten the lever arm will make the bar stiffer. Maybe not as stiff as a 1/38, but stiffer. If you are doing this mod only to the front you are going to make it understeer more than it soes now. You really need to tweek both ends.
Thanks..i also have a 7/8 inch aadco rear bar in now..so iwanted to balance it a bit...rearend plants alot better..and front leans more now...
Old Sep 4, 2007 | 05:04 PM
classj's Avatar
The gt500 coupe front bar has a heavier wall thickness. I dont have them on the car yet. Maybe next weekend.
robjh22
Custom Vanity Personalized License Plates & Brackets /Delete Brackets
14
Nov 1, 2015 11:28 PM
Mackitude
Aug 17, 2015 04:14 PM
Mackitude
Aug 13, 2015 01:05 PM
Jul 30, 2015 06:47 AM
killaz05
Jul 24, 2015 08:49 AM
