Steeda Bumpsteer Install Problem
Old Sep 6, 2010 | 01:42 AM
mikeelia's Avatar
So I made the mistake of leaving my 05 GT at a local shop to do the install of the steeda bumpsteer and x-2 ball joints. They called me and said that the ends were too long and they had to cut off around 1/4-inch of the thread to get the toe in spec on the left side. Normally, I stay to watch any work that is done [if I don't do it myself].
Forget the extra money they demanded for this with an explanation of "custom parts sometimes require custom work".
Can anyone chime in with any ideas of what is really wrong?
Car seems to drive fine, but the steering wheel is turned right slightly.
Old Sep 6, 2010 | 10:12 PM
Shotokan1509's Avatar
I'd talk to Steeda directly, I've dealt with Steve & Gus over there with great results. In my uneducated opinion, sounds like you found some guys that didn't know what the parts were really for.... same as giving ppl adjustable caster/camber plates, or bolts, etc.. add more adjustments than they are used to and heads explode.
Old Sep 6, 2010 | 10:53 PM
I installed the Steeda Bumpsteer on my '07 a few months ago and it was pretty easy. I can't imagine what they did wrong. Sounds like they messed up if they had to cut anything. And I'd be concerned about what it was they cut. Some pics would help us.
Old Sep 7, 2010 | 05:08 AM
yep first I've heard of anything needing to be cut to install bumpsteer.
Old Sep 7, 2010 | 05:53 AM
Scott2's Avatar
05 to 09 should use the Steeda X5 Bail Joint Kit (555-8108). Could this represent your install issue?
Old Sep 7, 2010 | 04:14 PM
take it back and tell them to make it right. Make the steering wheel right and then realign the front end. Hell they probably had to cut something because they didn't straighten the steering wheel first.
Old Sep 7, 2010 | 04:16 PM
Flagstang's Avatar
Spam Connoisseur
I got هَبوب‎ed
wheres Gus?
junkman9096
'10-14 Interior and Audio
May 12, 2016 12:43 AM
ustabawannab
Aug 5, 2015 08:32 PM
Jul 30, 2015 06:47 AM
Ecoboost
Jul 25, 2015 06:32 PM
killaz05
Jul 24, 2015 08:49 AM
