procharger on high mileage engine?
My Gt is approaching 90,000 miles. Id like to put a intercooled procharger kit on it in the near future. Would it be safe to say that id need new rings and seals throughout the engine before i even consider putting a procharger on it?
the car has been worshiped.. oil changes every 3000 miles and never abused
My car has 91k on it , had a MagnaCharger put on at about 30k , and I've had no problems and I still don't add any oil between changes. I use RP and I change it at 5k or less ...
+1 on the compression test ... Mine was put on early while the motor was still fresh , but if your engine has been maintained properly and is currently in good condition , i.e. the compression test , you should have no problems. Once you get the S/C the most important things are the tune and watching your A/F ratio ...
9/8/15 10:45 AM
