procharger on high mileage engine?
Old May 12, 2012 | 12:16 PM
Nates197's Avatar
My Gt is approaching 90,000 miles. Id like to put a intercooled procharger kit on it in the near future. Would it be safe to say that id need new rings and seals throughout the engine before i even consider putting a procharger on it?
the car has been worshiped.. oil changes every 3000 miles and never abused
Old May 14, 2012 | 05:37 AM
05YellowGT's Avatar
My car has 91k on it , had a MagnaCharger put on at about 30k , and I've had no problems and I still don't add any oil between changes. I use RP and I change it at 5k or less ...
Old May 29, 2012 | 07:22 PM
Nates197's Avatar
Wow that's impressive and good to hear! So basically if you take care of your ride like you should, you shouldn't have any problems?
Old May 30, 2012 | 01:00 AM
Antigini-GT/CS's Avatar
Founding MOTM
Committee Member
Compression test is your friend!
Old May 30, 2012 | 05:27 AM
05YellowGT's Avatar
+1 on the compression test ... Mine was put on early while the motor was still fresh , but if your engine has been maintained properly and is currently in good condition , i.e. the compression test , you should have no problems. Once you get the S/C the most important things are the tune and watching your A/F ratio ...
Uofmrampage
Aug 2, 2022 02:55 PM
mustangsally_
Sep 18, 2015 05:35 AM
GrabberBlue310
2012-2013 BOSS 302
Sep 17, 2015 08:21 AM
oldnjguy
Sep 10, 2015 02:39 PM
Sep 8, 2015 10:45 AM
