The GT Performance Timeslip Thread
#365
So much for not modding huh? hahahaha How you been?
I'll be ready will you? if the weather is nice I'll be heading to NYIRP on Sunday last test and tune of the year.
#366
Track Rental
2007 Shelby GT S/C Paxton 11.5, Alcohol Injection System Stage 2, ARH LT, X, HF cats, adj UCA, adj PHB, billet LCA with relocation brackets, Power House Alum. DS, loop, 410s, 31 spline Moser axles, TruTrac, MGW Shifter, line lock, WB fuel, boost cobalt gauges, MSD shift light mounted on SS pillar and running MT Streets 26x11.50.17.
My best out of 8 runs 11.432
First time back to the drags in 23 years boys and it can only get better ETs
#368
New best times
Last test and tune of the year for me...
Only got two runs (both the best of the year)here they are.
1st run after driving 1hr 20 min there
.607 R/T
1.845 60'
8.282 1/8
12.851 1/4
107.43 MPH
2nd run (hour later)
.746 R/T
1.893 60'
8.273 1/8
12.847
108.00 MPH
Clutch bit the dust..after this run...(maybe why my 60' times are up to snuff)
But at least I got into the 12's for the first time. Track was too cold track temp was 51 Air temp was 46.
.607 R/T
1.845 60'
8.282 1/8
12.851 1/4
107.43 MPH
.746 R/T
1.893 60'
8.273 1/8
12.847
108.00 MPH
#369
Current best, will scan the slip if needed but I SHOULD be getting a new best this week if all goes well!
R/T: 0.138
60': 1.798
330': 5.364
1/8: 8.323
MPH: 83.65
1000: 10.863
1/4: 13.010
MPH: 105.27
R/T: 0.138
60': 1.798
330': 5.364
1/8: 8.323
MPH: 83.65
1000: 10.863
1/4: 13.010
MPH: 105.27
#371
We need the 1st page updated!
Add another personal best for today. Seems like we had a few
R/T: 0.1437
60': 1.808
330': 5.32
1/8: 8.235
MPH: 84.75
1000: 10.73
1/4: 12.835
MPH: 107.15
Musta been because I was #69!
R/T: 0.1437
60': 1.808
330': 5.32
1/8: 8.235
MPH: 84.75
1000: 10.73
1/4: 12.835
MPH: 107.15
#372
Nice run!!!!!! with 1.697 60' you must be pulling to fronts off the ground!
How much air pressure you running in your M&H's?
what RPM are you launching at?
#374
Thanks. You say your clutch is toast? How many miles? How many 1/4 runs?
21,000 miles, about 25 runs down the strip, 2 days of road course racing and still seems fine.
I got my fingers crossed, lol.
#375
#376
#377
hum.. I ran 18lbs today....and "only" 4000 off the line.... And still the clutch went up in smoke.
How do you like the RPS clutch you have?
I have been noticing some slippage when going into 4th for about a month.
#378
Time to update the list! hehe New Personal best. Naturally aspirated
mods: JLTII CAI, Bamachips Race tune, O/R X, UDP, CMCV Delete plates, 4.10 gears,BFG DRs--rest of my mods are in the sig..
#379
I put in the 10.5" RPS clutch and Cynrg flywheel and it worked great.
As my power level increased I had to start slipping it out of the whole to get decent 60 foots. I put about 150 runs on that clutch. One night, against my better judgement I hotlapped 4 times slipping it hard out of the whole all 4 times. Next time I was at the track It was slipping. Granted I was still pulling high 1.6 60's with it, but it was slipping all the same. After teardown I found that I warped the plates in the flywheel. I then decided to see how great these SPEC clutches work. STG 2 with alum flywheel. I immediately noticed the car was a bit sluggish, the pedal pressure was a little lighter than the RPS, I could not control my launches with the SPEC, on or off at launch RPM and speed shifting 1-2 was not happenning.(YES IT WAS PROPERLY BLED)
Had the Cynrg flywheel rebuilt by RPS (125.00) like new. Put an exact replacement clutch and pressure plate from RPS back in. The car is back to normal. The RPS 10.5 set up is 3.5lbs lighter than the SPEC. I had a best of 12.7 with the SPEC-VS the 12.03 with the RPS, similiar weather and track conditions. Not knocking SPEC, but for my mods and driving technique the RPS is my choice by far.
#380
I smoked my stock clutch last year mostly due to power braking. I have installed line locks since.
ART;
Wow....the only difference between your 12.7 and 12.03 was the clutch. I've felt my stock clutch wasn't right for a long time but .7; boy would that validate my feelings.
Thanks for the info...I was looking at clutches all night last night, there are so many choices out there... I like the DFX centerforce clutch and I really like the Cynrg flywheeel design. I will look closer at the RPS now though...
While I was happy to finally get into the 12's I feel as though it has more in it...some tune, some setup and some (maybe more) from the clutch.
Thanks again for the info.. Much appreciated!!!!!
