Edelbrock Panhard Rod
Old Nov 18, 2009 | 12:36 PM
RedDragon777's Avatar
Anyone know anything about this, i found it on CJ Pony Parts for less than Steeda, BMR, and UMI. Would this be worth it for me since i am just looking for something to realign my axle after the lowering springs, or should i just go for the UMI. When i do start road racing this car i am going to switch to a Watts Link anyways and this will only be a temp fix till i can get my full suspension set up from Griggs.
Old Nov 18, 2009 | 06:25 PM
to me the Edelbrock name has always ment quality. They stand behind their stuff I say go for it
Old Nov 18, 2009 | 06:33 PM
fountainclimber's Avatar
We have one. Nice for the price. The instructions say it is already greased but it didn't look like it so I put some more in anyway. DO NOT OVERFIL!
We also added a thin stainless fender washer to the drivers side that is hardly supported by the factory bracket. Which brings me to a comment: All the LCA instructions that say you have to tighten at the ride height are incorrect. The reason is the stock pieces clamp on a tube permanently fixed to the rubber mount. Take out the rubber and the poly bushing spin as required. That is how they work. Not that it hurts but there is no need to try and get under the lowered car.
Oh yeah, one of the included grease fittings should angled instead of straight.
Just my 2¢.
Old Nov 18, 2009 | 07:06 PM
bob's Avatar
bob
I put one on my 07 GT, it looked/felt soild and I never had any problems with it. I also purchased Edelbrocks upper rear control arm, it was less confidence inspiring and I never got around to installing it (the BMR piece appears way beefier).
Old Nov 19, 2009 | 10:25 AM
Gleamin05's Avatar
I have one on mine.The price was right and its a nice looking piece.No complaints.Just like fountainclimber said the driver side grease fitting should be angled instead of straight.That reminders me I still need to change that !
Old Nov 19, 2009 | 11:30 AM
Just a question but why does the grease fitting need to be angled or is that just for convenience?
Old Nov 19, 2009 | 07:56 PM
The grease fitting points directly towards the bracket and it would have been hard to get at. I had to buy 5 so PM me address if you need one.
F
Old Nov 20, 2009 | 06:07 AM
Cali HP addict's Avatar
Been running the Edelbrock panhard, uca and lca's for 2 years now. Great pieces IMO. And yes, you need an angled grease fitting if you want to lube it on that end without removing it.
Old Nov 23, 2009 | 10:05 PM
bob's Avatar
bob
Cali, how much abuse have you put your Edelbrock UCA through? Compared to some others, the Edelbrock piece looks down right spindly and I'm hesistant about putting it on my GT500 (mother f'ing axle hop drives me crazy ) for fear it won't be up to the task.
Old Nov 23, 2009 | 10:21 PM
In your case i say go for the BMR or even the Steeda peice as you will be sticking to that suspension set up. I am only looking at this for a temp fix and it will not be beat on. When the time comes i am going to revamp my suspension to alot of FR500C parts and a Watts Link.
Old Nov 24, 2009 | 06:44 AM
I have abused them with street tires only. 285-40-18's to be exact. Part of this abuse was with 500/500 at the rear wheels. If I was to change anything I would put a Steeda UCA in place but I don't think you can hurt the Edelbrock lowers. Plus I really like the one bushing/one spherical end on the lowers. They work great, no bushing problems like BMR, they are chromolly so they are light/strong, and no increase in NVH that I can tell. Oh yeah, you can NOT make my car wheel hop. That s... is solid.
Bit of abuse, skip past the dyno http://www.youtube.com/watch?v=XaM2fjdX0LM
Old Nov 27, 2009 | 04:03 PM
bob's Avatar
bob
Sweet, I'm jealous I usually have to accelerate, get out of it and get back in it, otherwise it feels like I'm rolling over a washboard.
Old Nov 27, 2009 | 05:39 PM
Well either way, i am not going to get the bar. I wanted to get it for the price but from what CJ Pony Parts told me is that the bar is on backorder from Edelbrock and CJPP does not know when they will be able to get more of the bars. So i ended up going with a BMR bar.
Old Nov 27, 2009 | 08:05 PM
GRAYPNY's Avatar
I had a BMR bar before I went with the Watt's link and didn't have any problems. That should be fine.
Road_Runner
Sep 2, 2024 04:46 PM
09-gt/cs
Oct 15, 2015 10:03 AM
robjh22
Sep 8, 2015 12:31 PM
dohc97
Aug 3, 2015 06:26 AM
