panhard bar adjustment
Old Aug 2, 2015 | 06:52 AM
dohc97's Avatar
How do I adjust my panhard bar? The bar and lowering springs were installed by a shop for me at the same time. I need to move the wheels as little bit to the driver side. Do I need to jack up the car? Which way should I turn the nut to?
Old Aug 2, 2015 | 12:00 PM
houtex's Avatar
On the ground, or on a rack with the suspension loaded at all four corners. You then adjust the panhard bar, tighten, and off ya go.
You want to expand the space between the ends for what you want to do.. but each panhard is a little different on how that works. Just make it longer is what you're looking for to move the axle to the left side more.
Old Aug 2, 2015 | 07:28 PM
5.M0NSTER's Avatar
What houtex said. Here is a link to a PDF instruction for BMR bar.
http://1.cdn.lib.americanmuscle.com/...49606-cust.pdf
Old Aug 3, 2015 | 06:26 AM
Do the adjustment with 1/2 tank of gas in the car.
mx5jhb
Sep 30, 2015 04:44 PM
RoushRS3
Sep 29, 2015 08:03 PM
AJ_Trevino15
Sep 28, 2015 07:51 AM
Evil_Capri
Sep 25, 2015 12:56 PM
robjh22
Sep 8, 2015 12:31 PM
