Daily Drivers with UDP's
#41
Location: New Carlisle, Ohio (20 miles north of Dayton)
Just some thoughts..
Generaly the electrical system design is such that the alternator can, at idle, satisfy all likely-concurrent loads: lights, a/c, stereo (at a subset of max output), ECU, etc.
Underdrive pulleys are a two-edged sword: spin the belt and/or driven devices slower (alt, compressor, etc) and you WILL experience:
-reduced accessory losses (a few more HP, especially at higher rpm)
-reduced accessory output
If you have a tune on the car, you can use the programmer to set the idle higher to compensate for some of the pulley reduction. This is a good idea since it will not give back any of the power gains at but will keep the battery better conditioned.
If you're lucky, running underdrive pulleys will just shorten battery life (can be considerably shorter -- from 6-8 years to 1-3 years DEPENDING ON YOUR DRIVING SITUATION.
If you have a Shaker 1000 and like it LOUD and BASSY, drive in stop and go traffic for much of your commute in pre-dawn hours in Phoenix, don't be surprised if your batter life is even shorter than 1-year.
If your daily driving is typically a freeway commute with little or no dead-stopidling, your battery life may not be affected much at all, even with heavy accessory use: a/c, lights, stereo...
Most people think of a battery kinda like a jug of water, you drain it down and the alternator fills it up, and as long as it doesn't run out (you get ahead of the alternator for too long a period) you're ok.
But that analogy is not entirely a good one. Battteries are generally only elastic in the top 10% of their capacity -- the deeper you dip beyond that starts to shorten their life by more and more (disproportionately). Once you get to the point where you're discharging up to 40% or so (depends on the quality and design of the battery), life span is greatly reduced, especially if it sits in the reduced state overnight (as opposed to being recharged before shut-off. However, DEEP cycling of even a quality automotive battery beyond its design-point even with a 'full' recharge will greatly reduce its life (a deep-cycled impaired battery will never reach full capacity again). Marine batteries are designed for deeper cycling but give up some other capabilities in the trade (marine batts are not recommeded for cars).
A severe service battery (e.g. optima yellow/red-top) will prevent spills and take much more vibration, but will not last any longer than a conventional battery of similar capacity and cycle-design.
So the net is, IMO, asking others if pulleys worked ok for them is not usefull in predicting how pulleys will work for you. The specifics of the car (alternator capacity at idle), the climate, the battery design/capacity, the actual daily driving conditions and the actual habits of the driver ALL INTERACT UNIQUELY to determine if the battery is operating [too] deeply into its reserves or not on a regular basis.
To the extent it is, is to the extent your battery WILL fail prematurely, and how prematurely.
The engineers who designed the car took great pains to assure that you don't inadvertantly, and on a regular basis, dip into that reserve deeper than the modelled use scenarios of the car and working design parameters of the total electrical system permit.
When you change pulleys you fundamentally change those relationships: some under most conditions, but mostly under idle/slow-speed conditions. Depending on the above use factors, two identical cars can experience vastly different lifespans and failure rates for various electrical components with altered pulleys. Fortunately most will only see a shortened battery life and some will see almost no change, but others can and will see battery and component failure ---
---IT ALL DEPENDS...
Don't worry. The Steeda pullies will not let you down. BTW, welcome to the forum.
Scott
#42
check this out. if i drive in the city and stop and go traffic slamming the shaker 1000, the car will actually raise the idle after a little while. i think this car is smart enough to be like ok battery is getting low, engine make more electricity now!
#44
I had Steeda UDP's installed at about 10,000 miles. At 20,000 miles it caused one of the scariest problems i've ever encountered driving. The car slowly shut down piece by piece on the interstate. Started with the battery and ended with the speedometer buried in 0 mph while I was doing 65 mph. It fried my alternator. Ford replaced it no questions. Guess what happened at 35,000 miles....yup. Pullies were removed and the AC gets extremely cold now.
#45
#46
that's exactly what my car did
#47
It's not the pullies!!!! Think about it guys. If you have stock pullies and after a couple of years your battery starts to go bad. Should that cause your alternator to fry?? I don't think so. It is not the pullies!!! Ford would not replace your alternator if they thought it was the pullies. Show me some proof of these accusations please.
Scott
Scott
#48
Well I took my vehicle to Ford and they said the problem was the pullies (the car could barely start and the stereo would get low battery). So they removed them and the car has been much healthier (electrically)
Why would people make this up....get a life.
#50
Seems to me that spinning the alternator slower wouldn't cause it to burn up...... but it could be harder on the battery since it wouldn't be getting as much charge.
Would the alternator puke because it's trying to charge a battery that is at lower voltage than normal?
If the battery pukes because its not getting as much charge as before, would it kill the alternator?
Or did the alternator just quit for none of the reasons above? Isn't there a TSB on the alternator? Maybe that's why Ford would replace it even if they think it was caused by the pullies. It seems to me if they thought it was the pullies, they wouldn't replace the alternator under warranty if there were no known problems with the alternators already.
#52
Wow... we are all over the map here... my Steeda UDPs are sitting on my workbench waiting to be installed, but after reading this thread I'm getting worried.
What to do, what to do...
9/24/15 08:15 PM
