Coil on Plug TSB
Does anyone have a copy of the following TSB?
04-16-1
ENGINE MISFIRE OR ROUGH RUNNING - COIL ON PLUG (COP) IGNITION SYSTEMS - WDS COP KIT DIAGNOSTIC TIPS
When did the new parts become factory installed?
04-16-1
Found this . . . . .
TSB 04-26-22
Publication Date: December 23, 2004
Malfunction indicator lamp (MIL) illuminated with multiple diagnostic trouble codes (DTCS) P035X and no driveability symptoms - 4.6L 3V Engine
ISSUE
Some 2005 Mustang vehicles equipped with a 4.6L 3-valve engine, may exhibit the MIL illuminated with multiple ignition coil related DTCs (P035X) and no driveability symptoms. The DTCs are typically set during deceleration.
ACTION
Do not replace ignition components for this condition. Reprogram the powertrain control module (PCM) to the latest calibration using WDS release B34.10, or B35.1 and higher. Calibration files may also be obtained at www.motorcraft.com.
Here's a Word doc that contains TSB 04-16-1
[attachmentid=24302]
TSB 04-26-22
ISSUE
ACTION
9/23/15 03:21 PM
