blinker problems
1 Post
Has anyone else had a problem with their blinker blinking faster when your indicate right and the normal blinking speed when you turn left. I checked all the lights and they are workin properly.
Originally posted by Ford05MustangGT@August 7, 2005, 4:42 PM
That's strange, it should only do it if one of the lights is out.
Or wrong bulb even. maybe bad connection/ground in one.
WRONG. You are obviously low on blinker fluid on the slow side. Better top it off before you cause undue friction and wear.
Sean
PS - I have no idea what is wrong, I have just never had an opportunity to suggest blinker fluid before.
Sean
Originally posted by don_w@August 8, 2005, 1:50 PM
Brandon.. nice avatar BTW... since I took that photo and my car is one of the two in that pic, do I get royalties?
Very nice pic.
If it's really still bothering you, switch the builds around as see if the problem follows the bulbs
1 Post
blinker fluid... very funny guys. Well thanks for the info, ill change all the bulbs around and see what happens. good jokes though, I know I was opening myself up on that one.
Originally posted by don_w@August 8, 2005, 12:48 PM
I switched to synthetic blinker fluid... gained 5rwhp!
Originally posted by Ford05MustangGT@August 8, 2005, 1:29 PM
I'll put a credit in my sig.
Very nice pic.
Very nice pic.
If you are sure that there are no bulbs that are out, then take it to the dealer to have it checked out.
Just double check the lights again to be sure though. It's probably something simple.
Rando
8/25/21 11:12 AM
