blinker problems
Old Aug 7, 2005 | 03:25 PM
AircraftTech's Avatar
Has anyone else had a problem with their blinker blinking faster when your indicate right and the normal blinking speed when you turn left. I checked all the lights and they are workin properly.
Old Aug 7, 2005 | 03:39 PM
Stang281's Avatar
That's strange, it should only do it if one of the lights is out.
Old Aug 7, 2005 | 03:43 PM
Stoenr's Avatar
Or wrong bulb even. maybe bad connection/ground in one.
Old Aug 7, 2005 | 05:40 PM
azoufan's Avatar
WRONG. You are obviously low on blinker fluid on the slow side. Better top it off before you cause undue friction and wear.
Sean
PS - I have no idea what is wrong, I have just never had an opportunity to suggest blinker fluid before.
Old Aug 7, 2005 | 06:31 PM
Sonic05's Avatar
Maybe the car is trying to tell you something?
I don't know, sorry, I just had to make some dumb comment.
Old Aug 7, 2005 | 07:51 PM
ex-Galaxie500's Avatar
Check the fuse or, more importantly, try replacing it-- That's what I would do anyway
Old Aug 7, 2005 | 08:08 PM
StangNut's Avatar
Has to be a bulb. They all blink from the same flasher.
Has it done it since day one?
Old Aug 8, 2005 | 12:45 PM
don_w's Avatar
I switched to synthetic blinker fluid... gained 5rwhp!
Old Aug 8, 2005 | 12:47 PM
don_w's Avatar
Brandon.. nice avatar BTW... since I took that photo and my car is one of the two in that pic, do I get royalties?
Old Aug 8, 2005 | 02:26 PM
Stang281's Avatar
I'll put a credit in my sig.
Very nice pic.
Old Aug 8, 2005 | 02:44 PM
Lowe!'s Avatar
If it's really still bothering you, switch the builds around as see if the problem follows the bulbs
Old Aug 8, 2005 | 03:17 PM
blinker fluid... very funny guys. Well thanks for the info, ill change all the bulbs around and see what happens. good jokes though, I know I was opening myself up on that one.
Old Aug 8, 2005 | 09:56 PM
StangNut's Avatar
Let us know how it turns out.
Old Aug 8, 2005 | 11:02 PM
Dan's Avatar
Dan
Do You Remember Me?
I say Bulb.....check back and front.
Old Aug 9, 2005 | 12:37 AM
TURBO 05's Avatar
dont forget to add a sticker from the synthetic blinker fluid to add another 8 rwhp
Old Aug 9, 2005 | 12:03 PM
Lucky_Stang's Avatar
Very nice pic.
And since mine is the other car do I also get royalties?
Old Aug 9, 2005 | 01:01 PM
ryan1112's Avatar
If you are sure that there are no bulbs that are out, then take it to the dealer to have it checked out.
Just double check the lights again to be sure though. It's probably something simple.
Rando
Aug 25, 2021 11:12 AM
Mpaps
Oct 11, 2017 08:06 PM
tukatz
Off-Topic Chatter
23
Oct 20, 2015 09:54 AM
09-gt/cs
Oct 15, 2015 10:03 AM
boz
Oct 1, 2015 04:47 PM
