06 stock T-Body porting how to
Old Sep 27, 2008 | 07:38 PM
Redrocket06's Avatar
What up guys, if you are thinking of buying an aftermarket TB you might try this first. The aftermarket ones I understang offer almost 0 gain on a mild modded stang, so with this you can decide if you want to smooth out the way the stocker flows or buy a new one.....I felt almost 0 gain, but then again I am not making 500 hp.
Stock TB backside
http://i301.photobucket.com/albums/n...6/DSC01086.jpg
http://i301.photobucket.com/albums/n...6/DSC01087.jpg
Screws ground down
http://i301.photobucket.com/albums/n...6/DSC01089.jpg
http://i301.photobucket.com/albums/n...6/DSC01090.jpg
TB back screws ground down and edges opened some and rounded
http://i301.photobucket.com/albums/n...6/DSC01092.jpg
TB front stock
http://i301.photobucket.com/albums/n...6/DSC01093.jpg
TB Front one side done rough
http://i301.photobucket.com/albums/n...6/DSC01094.jpg
TB done
http://i301.photobucket.com/albums/n...6/DSC01095.jpg
http://i301.photobucket.com/albums/n...6/DSC01096.jpg
http://i301.photobucket.com/albums/n...6/DSC01097.jpg
TB done installed
http://i301.photobucket.com/albums/n...6/DSC01101.jpg
http://i301.photobucket.com/albums/n...6/DSC01102.jpg
TB oops (don't do this, learn from my mistake)
http://i301.photobucket.com/albums/n...6/DSC01099.jpg
http://i301.photobucket.com/albums/n...6/DSC01100.jpg
Tools
http://i301.photobucket.com/albums/n...6/DSC01088.jpg
http://i301.photobucket.com/albums/n...6/DSC01098.jpg
OK, on the oops.. The metal is not as thick as I thought, I should have looked closer before I started and would have seen it. The first side I did is the one I messed up, but the left side I did good. I did a temp fix on it by putting hi temp RTV on the outside to cover the hole and made sure non was on the inside and let it dry before driving.
Driving impression: Little-no gain, but fun to do. Maybe some help on the top end. Zero affect on driveability, and no CEL after 500 miles. This could be the S197 first free mod!
Old Sep 27, 2008 | 07:41 PM
The last tb I ported was a 80mm BBK on my 2001 Silverado (came out awsome, BTW). It had a ton of meat to port so I was going off the way I ported that one not realizing the stock stang one was not a meaty.
Old Sep 27, 2008 | 07:44 PM
05GT-O.C.D.'s Avatar
I lust for a M24
Nice, thanks for the idea. Do A/M TB's have larger diameter butterflies?
Old Sep 28, 2008 | 09:47 AM
travelers's Avatar
I didn't actually port mine but just polished the inside to smooth it.
Old Sep 28, 2008 | 06:58 PM
Do you mean GM instead of A/M? If so they do not run a twin tb any more, they run a large single hole. My factory 2001 silverado was a 78mm or 76mm. The 80mm and even a 90mm for high performance LSX are popular.
Old Sep 28, 2008 | 07:17 PM
I lust for a M24
No, I meant AfterMarket. Are you getting any gains from the bigger inlet, or just hoping for smoother airflow?
Old Sep 29, 2008 | 06:21 AM
metroplex's Avatar
Leave it stock. Nothing good can come from porting/polishing a throttle body.
Old Sep 29, 2008 | 06:37 AM
I lust for a M24
Why do you feel the need to throw your .02 in all the time and pee in people's Wheaties?
Some people enjoy projects like this regardless if the provide additional HP gain or not. Personally, I appreciate him posting his project and being willing to give it a shot and posting his feelings afterwards. It helps allow someone else to decide whether or not they want to try it themselves.
Old Sep 29, 2008 | 08:39 AM
metroplex's Avatar
I'm all for fun DIY projects as much as the next gearhead, but nothing good can come from porting the throttle body. If you mess up, you can cause more problems in the long-run especially with these new drive-by-wire systems. I wouldn't even recommend porting the throttle body on a pre-05 Mustang/Ford. Even cleaning it using the wrong type of cleaner can result in unusual idle or driveability conditions.
Old Sep 29, 2008 | 10:13 AM
RRRoamer's Avatar
Redrocket06,
You could also use some JB Weld to patch that. Let it set up and then sand it smooth with the rest of the throttle body. If the aluminum is clean, that is pretty much a permanent patch.
My dad patched a hole in the oil pan on our van while out in the woods on a dear hunting trip with the stuff. When he sold the van 10 years later, it STILL had that JB Weld patch on the pan and it still didn't leak.
Old Sep 29, 2008 | 10:36 AM
blkstang06's Avatar
Old Sep 29, 2008 | 12:38 PM
highvolts's Avatar
Nice! The only thing I would of done differently is use less agressive cutting tools. Those look really agressive!
Thanks!
09-gt/cs
Oct 15, 2015 10:03 AM
exgto
2012-2013 BOSS 302
Oct 7, 2015 01:47 PM
Ray11
Sep 25, 2015 12:43 PM
jim010
Sep 7, 2015 02:40 PM
