Secondary USB port used with Sync
Old Oct 18, 2013 | 10:53 PM
tukatz's Avatar
I found information on the secondary USB port in late models (mine is a 2014) and found the port and plugged in a micro USB to standard USB cable. I added a female/female coupler and plugged my thumb drive into it. Sync found it immediately without my having to do anything else and simply picked up where it had left off playing music.
I now have both power ports and the USB port in the center console available for charging phones, etc. and still have my thumb drive providing many hours of music through Sync.
Old Oct 19, 2013 | 06:35 AM
Ajcruz1's Avatar
Sweet. Thanks for sharing. Where was it located?
Old Oct 19, 2013 | 09:58 AM
tukatz's Avatar
The Sync module is a black box up behind the glove box. When you open your glove box you can push the sides toward the center to get 'stops' to clear the outer frame and the box will drop down further. There is a cable coming out of the black box and next to it is a micro USB port. I ordered the female/female coupler from monoprice.com for a few bucks. My cable is coiled and tied and the large USB end is draped over the back of the glove box so it is accessible with the glove box in the normal open position. That way I can easily remove my thumb drive if I want to add more music to it.
There is a thread on here somewhere that has photos of the procedure I described, but I don't think you need them. The photo shows the type of micro USB needed.
Old Oct 20, 2013 | 08:19 AM
sakol's Avatar
Are you using an iPhone 5 with it ? Or another kind of phone?
Old Oct 20, 2013 | 09:48 AM
denlem's Avatar
Check out my thread on using this port!
https://themustangsource.com/f803/ad...e-sync-511051/
Old Oct 20, 2013 | 10:53 AM
tukatz's Avatar
I'm not using a phone. I have a 32GB USB thumb drive with somewhere close to 300 albums on it. The thumb drive was really cheap (an HP through Amazon) and is only about 1" long. I spent a fair amount of time working on setting up the music files with the correct tags so I can initiate music with voice commands playing artist, album, track, or genre.
My USB cable connects to the secondary USB port, the coupler connects to the large end of the USB cable, and the thumb drive plugs into the other female side of the coupler.
Old Oct 20, 2013 | 10:54 AM
tukatz's Avatar
Thanks. I used your instructions but figured I would not be able to find your thread again.
Old Oct 20, 2013 | 02:32 PM
denlem's Avatar
Just make sure you're subscribed to a thread you like. Then when you need to find it again, you only need to go through your subscriptions. Makes things easier to find later. That's what I do.
Old Dec 5, 2013 | 05:25 PM
ghjr's Avatar
Good tip, thanks for the info!
junkman9096
'10-14 Interior and Audio
May 12, 2016 12:43 AM
HizliBullet
GT350
14
Nov 14, 2015 08:59 AM
yabutt
Oct 23, 2015 01:05 PM
PonyMuscletang13
Sep 26, 2015 02:33 PM
jim010
Sep 7, 2015 02:40 PM
