Secondary USB port used with Sync
I found information on the secondary USB port in late models (mine is a 2014) and found the port and plugged in a micro USB to standard USB cable. I added a female/female coupler and plugged my thumb drive into it. Sync found it immediately without my having to do anything else and simply picked up where it had left off playing music.
I now have both power ports and the USB port in the center console available for charging phones, etc. and still have my thumb drive providing many hours of music through Sync. |
Sweet. Thanks for sharing. Where was it located?
The Sync module is a black box up behind the glove box. When you open your glove box you can push the sides toward the center to get 'stops' to clear the outer frame and the box will drop down further. There is a cable coming out of the black box and next to it is a micro USB port. I ordered the female/female coupler from monoprice.com for a few bucks. My cable is coiled and tied and the large USB end is draped over the back of the glove box so it is accessible with the glove box in the normal open position. That way I can easily remove my thumb drive if I want to add more music to it.
There is a thread on here somewhere that has photos of the procedure I described, but I don't think you need them. The photo shows the type of micro USB needed. http://i1115.photobucket.com/albums/...ps9e767af4.jpg |
Are you using an iPhone 5 with it ? Or another kind of phone?
Originally Posted by sakol
(Post 6703221)
My USB cable connects to the secondary USB port, the coupler connects to the large end of the USB cable, and the thumb drive plugs into the other female side of the coupler. |
Originally Posted by denlem
(Post 6703251)
Originally Posted by tukatz
(Post 6703267)
Thanks. I used your instructions but figured I would not be able to find your thread again.
Good tip, thanks for the info!
