Stalling issue on 2008 Mistang GT
Old Nov 15, 2012 | 08:31 AM
Victorfriessen's Avatar
My car starts up and stalls after 2 sec, does anybody know what could cause this?(p2105) thats the only code I get
Maf is reading 72,got a new one (still same)
Coils- checked
Crank sensor - checked
Tune- checked
Fuel pump- (It gives pressure)
Throttle body and sensor- checked
Old Nov 17, 2012 | 10:52 AM
DPHC13's Avatar
while it IS running is it sputtering or running like crap? Or does it just start and quit? I have forgot to plug things back in like the MAF, and other stuff under the hood and that has happened. Were you doing anything to the car before this happened?
Old Nov 18, 2012 | 09:12 AM
I only get the engine to run ,still like crap , when unplugging the maf,as soon I connect the maf it shuts down,and the car runs extremly rich- 10.2 at idle-
Old Nov 20, 2012 | 05:28 PM
DPHC13's Avatar
Have you tried cleaning the MAF? Or maybe if you know the correct voltage you could check to see if it's operating properly. Oh. sorry just looked at the original post and I see that you changed the MAF... Uh... I hope someone can chime in here and give you a hand. I don't have time to read all this but maybe it could help.....http://articles.d-tips.com/art8.html
Old Nov 20, 2012 | 05:31 PM
Seems like one guy put his in upside down and had problems.
O2 sensors connected properly?
Old Nov 20, 2012 | 05:59 PM
tapd117's Avatar
Are you using a K & N Filter by any chance, fresh oiling can do this to the MAF. Pretty obvious MAF could be issue. I'll look up my codes and get back to you.
I was poking around with the diablosport tuner and it found a few faults, one of which was P2105 : Throttle Actuator Control System - Forced Engine Shutdown
*Note: This came from another forum on the code, may be of some help.
GG
Old Nov 21, 2012 | 06:18 PM
I thought of the oiling to but I did replace it with a new maf sensor and still got the same issue but now I finally got it fixed,I changed the spark plugs and wualla!! Ho had thought it could be the spark plugs,I had new ht0 autolite installed about two month ago
Old Nov 21, 2012 | 06:19 PM
And thanx to everybody ho tried to help
Old Nov 21, 2012 | 06:27 PM
Don't superchargers require a cooler plug? Could that be why they are failing and not burning fuel off? The wet plugs is why I thought of messed up O2 sensors as another thing to check.
Old Nov 21, 2012 | 06:45 PM
The stock plugs are ht1 and the colder ones are ht0 and I checked the o2 sensor
Old Nov 21, 2012 | 06:50 PM
Glad you got it figured out.
Old Nov 21, 2012 | 07:17 PM
Yea its nice to have my Mustang back to life,if its another vehicle I dont give a ***** but when its the mustang the time cant go fast enough to figure out what it is and fix it
Another problem when you plug the o2 sensor reversed so it tries to adjust the wrong bank and that messes up big time
Road_Runner
Sep 2, 2024 04:46 PM
kponypower
Jun 17, 2020 07:17 AM
09-gt/cs
Oct 15, 2015 10:03 AM
Antigini-GT/CS
Oct 5, 2015 09:43 AM
