Special Tool for changing fuel filter???
Old Mar 20, 2007 | 08:53 PM
samckernan's Avatar
Aparently there is a special tool for changing the fuel filter (specifically for removing the fittings). Anyone know what it is, where I can get one, etc...
Old Mar 20, 2007 | 09:26 PM
f1-cobra's Avatar
I remember a few years ago when I changed the fuel filter on our Lincoln, it called for a special tool. It was just a tool to make it easier to get it out. I can't remember what I used, but I know I didn't buy one and I replaced it with regular hand tools. It was mounted under the splash guard in the front wheel well.
Old Mar 21, 2007 | 04:38 AM
hawgman's Avatar
There is? Hummm. Certainly don't remember needing one when I changed mine.
Old Mar 21, 2007 | 05:00 AM
metroplex's Avatar
There are 3 different types of fuel filter retainers used on late model Fords with the same fuel filter!
One method uses a plastic hairpin clip. You push in a barb and pull out the hairpin, re-use if it is intact.
Another method requires the special spring lock coupler tool (used for A/C and fuel lines). The white plastic tools sold at Sears (Lisle) work VERY well. Just push them in and it magically decouples the spring lock.
The last method that I've seen is kind of funky and I've never had 1st hand experience with it. As far as I know, no tools are required. You just pull off a lock retainer or something. I wish I had my FSM with me right now. These were used on the latest Fords when I last checked.
Old Mar 21, 2007 | 06:08 AM
dly's Avatar
dly
I just took off my Fuel Rails (to paint) and I needed a special tool. I brought it form Autozone. You get 4 different sizes in the kit, its $9.99 and I think i used the Black one. It just opens and fits around the fuel fitting and up push it against the bigger side and it tops off. The kit says it for Ford A/C quick dissnect but it work for the fuel lines. Hope this helps
Old Mar 21, 2007 | 05:29 PM
Robbieg's Avatar
Something like this should be what you need. I think I got it at Autozone but it's been a while.
Attached Thumbnails Special Tool for changing fuel filter???-1111.jpg   Special Tool for changing fuel filter???-2222.jpg
Old Mar 21, 2007 | 05:55 PM
metroplex's Avatar
Sears has the full set (more than just 4) for $10 (Lisle).
I have not changed the fuel filter on a S197 myself, but the FSM appears to be quite vague.
It describes the couplings as "quick connect" and not the spring lock, which means the tools that we are talking about are not required.
Instead there are 3 types of quick connect couplings described by the FSM.
Attached Thumbnails Special Tool for changing fuel filter???-filter_couplings.jpg
Old Mar 21, 2007 | 06:24 PM
f1-cobra's Avatar
I spoke too soon. After seeing these it reminds me that my brother had one of these tools. It looked like one of these:
I got this pic from sears.com
Old Mar 21, 2007 | 06:38 PM
metroplex's Avatar
F1-Cobra: 9/10 people that used that tool said it sucked big time. The Lisle and Autozone tools that you use to push in the spring lock coupling work beautifully.
Old Mar 21, 2007 | 06:44 PM
NJ3's Avatar
NJ3
I have one of those, they do SUCK BIG.
Old Mar 21, 2007 | 07:40 PM
Sharky's Avatar
Ditto
Old Mar 21, 2007 | 10:39 PM
Stoenr's Avatar
No tools required to remove filter. 2 different sized sockets to remove the plastic cover hiding it tho. Changed mine last month, took all of 10 minutes.
Old Mar 21, 2007 | 11:23 PM
samckernan's Avatar
Thanks you guys...
One more question. Where is the fuel filter located? Under the hood, under the car, or back by the tank?
Old Mar 21, 2007 | 11:28 PM
Stoenr's Avatar
Originally Posted by samckernan
Thanks you guys...
Under the car, drivers side, about in the middle. has a long black cover over part of the lines and filter that needs to be removed, not fully removed tho.
Old Mar 22, 2007 | 03:25 AM
metroplex's Avatar
So which type of connection was it?
http://forums.bradbarnett.net/showpo...87&postcount=7
Old Mar 22, 2007 | 07:09 AM
Stoenr's Avatar
I wanna say its the 1st style in the picture.
Old Mar 22, 2007 | 09:15 AM
06GT4RAD's Avatar
Yep they should be the Type 1 that only require you to push them inward. What ever you do. Do Not try and remove them as they will break and most dealerships do not stock them.
Richard
NC14GT
Feb 20, 2023 09:42 AM
Mpaps
Oct 11, 2017 08:06 PM
Fastnloud
Feb 15, 2016 05:21 PM
TripleBlack14
Sep 17, 2015 07:48 AM
