Automatic Passenger Window
Guest
Posts: n/a
Hey Everyone,
I have a 2006 Mustang GT and had a quick question. I know that the driver/passenger windows can automatically go down with one push on the drivers window controls on the door. I thought that both windows automatically go up with one pull on my car, but only the drivers window goes up automatically. With my passenger window, I need to pull and hold the window switch to get the window to close. Are both the driver/passenger windows automatic when rolling up the window, or is the drivers only automatic?
Thanks!
Mike
Thanks!
Mike
Mine did that once. You can reset it by (I think) cycle the window down then back up, holding the switch up for at least five seconds. This resets the up stop. Check the manual to be sure, but I know I corrected this problem on mine.
Roll down the passenger side window all the way. Roll it back up all the way and let go of the switch for a few seconds. Now hold the switch in the "Window up" position for 2 seconds and release. That resets it. After this, if your window does not automatically roll up contact the dealer. Approx once out of ever 10 times I use the passenger side window I have to reset it. I have never had this issue with the Drivers side window.
iliveonnitro
10/7/21 06:31 PM
