Break LIGHT problem!!
Old Mar 18, 2012 | 11:41 PM
Fastang97's Avatar
Hoping someone can help or has gone through this and fixed it... Whenever I brake my brake light comes up on the dashboard... I don't even break hard and the break pads and everything else looks good... Even when I am just driving the light goes on without even pressing the breaks... What's wrong??
Old Mar 18, 2012 | 11:46 PM
11SHELBYGT500's Avatar
Your brake lights are supposed to come on when you hit the brakes.
Old Mar 18, 2012 | 11:48 PM
Fastang97's Avatar
Haha oops... I mean the break light on the dashboard... The one that comes up when you have the emergency break on
Old Mar 18, 2012 | 11:56 PM
That's very strange the only thing triggering that should be the switch on your emergency brake.
Old Mar 19, 2012 | 12:02 AM
Fastang97's Avatar
Yes and it is bugging me so bad... Every time I step on the gas and hit 40mph the dumb thing comes up and usually stays on for a minute or until I completely stop.
Old Mar 19, 2012 | 12:04 AM
How long has been going on and has there been any work done to the car since it started happening?
Old Mar 19, 2012 | 12:07 AM
Fastang97's Avatar
It started last month and now the light is getting annoying... And no the car hasn't had any work on it I have been the only owner besides my dad... Guess I should get it checked
Old Mar 19, 2012 | 04:36 AM
05GT-O.C.D.'s Avatar
I lust for a M24
Check your brake fluid level and see if it's low. Speed really shouldn't affect any of it though.
Old Mar 19, 2012 | 06:39 AM
Dread53's Avatar
Same thing happened long ago to a customers 88 Turbo Coupe. The level sensor was covered when level but uncovered when hitting the brakes.
Old Mar 19, 2012 | 01:30 PM
Fastang97's Avatar
Ok thanks... I added brake fluid and it was low... Thanks for the help
Old Mar 19, 2012 | 04:28 PM
I lust for a M24
Good to hear. Here's another .02.
Brake fluid normally goes low for 2 reasons - 1) a leak, or 2) pads are worn. Neither are good, so if it goes low again, make sure to get it in to the brake shop to avoid having a really bad day.
Old Mar 19, 2012 | 07:34 PM
houtex's Avatar
Um... not to derail totally, but isn't the reason the things get low due to two things?
1) Leak somewhere.
2) pads/shoes are wore out, causing the resevoir to be low because the fluid's in the caliper/slave pistons.
Now, granted, a long lived car 10 years old might seep the teeniest and it eventually weeps through to the 'outside' and is lost that way... over time... But excepting that... am I wrong in my thoughts?
Worn pads= when replacing, the now full resevoir fluid will be expelled. Be forewarned, you will be gettin' messy when that happens.
Old Mar 19, 2012 | 08:04 PM
I lust for a M24
1) Leak somewhere.
Just wondering if you saw the post directly above yours?
Mpaps
Oct 11, 2017 08:06 PM
seaclam
Sep 25, 2015 01:29 PM
DrisStang
Sep 14, 2015 06:20 PM
14Glassback
Sep 11, 2015 04:50 PM
Hristofor
1994-2004 V-6
Sep 11, 2015 12:05 PM
