Brake help
Old Mar 8, 2012 | 07:30 PM
NYGMEN's Avatar
Brake help
I installed new pads about 2 weeks ago on the front. They were squeeling coasting and the noise would go away when applying the brakes. I used grease on the clips and tightened everything as it should be. The noise went away. Occasionally it would squeek a little still though while coasting. It was intermittent though. Well the squeeking seems to have stopped but now when stopping under 5 mph, the brakes are making like a grab or clunking noise that can be felt in the brake pedal. New rotors? Help..
Old Mar 8, 2012 | 09:57 PM
how many miles are on the car? I ask because maybe you have a caliper problem. How did the rotors look when you replaced the pads? Does it feel like the car stops smoothly or does it seem to have a stop and go feel to it?
Old Mar 8, 2012 | 10:04 PM
cpotts13's Avatar
If you didn't turn the rotors and break in the new pads then that may be the squealing and clunking. Or you didn't tighten everything right. Check the bolts again. You BREED to turn/ replace the rotors when replacing brake pads.
Old Mar 8, 2012 | 10:14 PM
NYGMEN's Avatar
The car seems to stop smoothly. Just a noticeable knock or cluck occasionally when braking under 5mph. Car just turned 80k on the clock. I didn't replace anything but the pads. It weird it has been a couple weeks since I replaced them and the first time it happened was today
Old Mar 8, 2012 | 10:30 PM
NYGMEN's Avatar
The rotors looked ok I'm not sure the age of them though, they were on the car when I got it close to a year ago
Old Mar 9, 2012 | 06:53 AM
cpotts13's Avatar
Definitely get down there and check if everything's tight. Maybe the brake pads are moving around?
Old Mar 9, 2012 | 09:09 AM
stupidgenius36's Avatar
Just Plain Rude!
I think I know exactly what you're talking about. I just recently had my brakes done. They squealed a little bit, and did the clunking thing at first. But I've noticed that it's mostly gone away after breaking them in.
Definitely make sure everything is tight. And if you didn't get the rotors turned, then do so ($15 each at o'reillys). Other than that, I'd say just give them some time to break in and see if it goes away.
Old Mar 9, 2012 | 10:56 AM
NYGMEN's Avatar
Thanks man I will give it a little time to see if I clears up. The weird thing is that it doesn't do it at all when the car is cold. Only after it has built up some heat. I checked to make sure everything was tight. If it doesn't get better then I will start over with turned or new rotors I suppose
Old Mar 9, 2012 | 06:45 PM
it really doesn't sound like you need to turn the rotors. The car stops smoothly so my guess is its something else
Old Mar 9, 2012 | 07:23 PM
cpotts13's Avatar
Any suggestions?
Old Mar 9, 2012 | 10:49 PM
NYGMEN's Avatar
It does stop smoothly. Even when it is making the noise and sending the vibration of the noise through the pedal.
Old Mar 10, 2012 | 07:16 AM
NYGMEN's Avatar
Is it possible that one of the brake pads is shifting a little bit. Everything is tight but they are the middle of the road 40 dollar autozone brake pads.
Maybe not exact fit?
Old Mar 10, 2012 | 06:34 PM
jack it up and spin the wheel, see if it hangs up at all. Spin the wheel as fast as you can and have someone hit the brakes lightly, spin the wheel again have someone hit the brakes hard then let off and see how easily the tire spins. Report back!
Old Mar 11, 2012 | 09:31 PM
NYGMEN's Avatar
Well good news. It's fixed. Bad news is I'm a complete idiot. I should be ashamed lol. So I did the brakes at this little place we have here on fort Lewis. You can use this building full of car lifts for 4 dollars an hour per lift. You can also use their tools. So when I put the wheels back on after the initaI brake job, i used their impact wrench. Well when I went back today to try and diagnose the brakes. All the impact guns were being used. So I used my breaker bar that I brought. When I went to loosen the lug nuts I had to apply almost zero pressure to them and they turned loose. When I saw this I knew right away that was the problem. I almost didn't even bother to take the wheel off. I did though just to be sure. Everything I tighten with my sockets was good the pads looked good. I tighten it back up. Put the wheel back on and tightened it with my breaker bar. Guess what.. No noise at all. So I guess we can put a hash mark in my retard column. Thanks for all your help though gents. I'm still happy it was something easy to fix. Imagine that if your wheels aren't tight they make noises.
Old Mar 11, 2012 | 10:16 PM
cpotts13's Avatar
That is so freaking cool that there is a place like that!!!! I wish there was something like that where I lived!
Old Mar 12, 2012 | 01:15 AM
Just Plain Rude!
Glad you didn't lose a wheel while you were on the road. And I wish the bays here were that cheap...$10/hr or $20/hr with a lift.
Old Mar 12, 2012 | 09:55 AM
David96GT's Avatar
When I was in the Service, where I was stationed there were personal vehicle "Hobby Shops". It was a huge open warehouse with 20 - 25 Self-service lift bay areas that you could rent per hour. Also on site was a Tool room that had every tool under the sun that you could rent too! Volunteer Gear-heads would donate their time and go from bay to bay to see if you needed any help or advice. I wish there was a place like that where I live now. Especially after the ordeal I went thru last weekend changing my Transmission filter and fluid on self maintenance service ramps. Geez!
Old Mar 12, 2012 | 10:55 AM
NYGMEN's Avatar
It certainly allows you to do many things that you would normally have to pay to have done or at a minimum have a floor jack and jack stands. Very nice to have around. Providing you check and make sure your lug nuts are tight by hand when your done working. Lol
Old Mar 12, 2012 | 11:54 AM
cpotts13's Avatar
You tighten the lug nuts in the air and torque them when the car is on the ground.
Old Mar 12, 2012 | 12:00 PM
Just Plain Rude!
Maybe yall do have one nearby, and just don't realize it. I lived here for 4 years, before I realized I had one 3 blocks from my apartment.
