Battery keeps dying
Battery keeps dying
So my battery is getting drained somehow, I have a 10" JL Audio PowerWedge subwoofer that's powered by a 250 watt amp. Would that draw enough power to drain my battery? I've run it for about half a year now with no problem. Any advice would be awesome.
Nope, maybe once every couple months, otherwise the car is on all the time. I installed a power switch on the turn on lead and that's done nothing. I'm thinking either buy a capacitor or buy a switch for the actual power
I'm guessing the alternator doesn't supply enough amperage. My battery is maybe 9 months old
Parasitic draw. Disconnect the amp. If it dies still then its not that. If you really want to find it you will need a multimeter. Then I can tell you has to find your problem.
I had a 5.0 that was charging great and it still turned out to be a bad alternator. After completing a parasitic draw test we determined the alternator was causing the short. If we let the car sit more than about 12 hours the battery would be dead.
Just a thought
Just a thought
Just a thought
Just a thought
PonyMuscletang13
9/29/15 10:40 AM
