Battery keeps dying
Old Sep 18, 2011 | 10:41 PM
JDF's Avatar
JDF
Battery keeps dying
So my battery is getting drained somehow, I have a 10" JL Audio PowerWedge subwoofer that's powered by a 250 watt amp. Would that draw enough power to drain my battery? I've run it for about half a year now with no problem. Any advice would be awesome.
Old Sep 18, 2011 | 10:44 PM
las0mbra's Avatar
Are you running it with the car off? Cause I have an alpine 500 amp with a type r 12" and it's fine
Old Sep 18, 2011 | 11:06 PM
JDF's Avatar
JDF
Nope, maybe once every couple months, otherwise the car is on all the time. I installed a power switch on the turn on lead and that's done nothing. I'm thinking either buy a capacitor or buy a switch for the actual power
Old Sep 18, 2011 | 11:13 PM
las0mbra's Avatar
Hmm... That's odd. Maybe an alternator or your batteries bad...?
Old Sep 18, 2011 | 11:19 PM
JDF's Avatar
JDF
I'm guessing the alternator doesn't supply enough amperage. My battery is maybe 9 months old
Old Sep 18, 2011 | 11:33 PM
las0mbra's Avatar
Hmm, that's weird. Yeah, it probably is your alternator. You might be able to get a shop to test it for you...
Old Sep 18, 2011 | 11:39 PM
JDF's Avatar
JDF
Yeah, I work at a ford dealer, I just never have the time to bring it in
Old Sep 19, 2011 | 03:47 AM
Autotooner's Avatar
My C/T is cooler than Arin is.
possibly check the alternator plug in. I think the factory one's were problematic
Old Sep 19, 2011 | 05:32 AM
maybe make an appointment?
Old Sep 19, 2011 | 07:40 AM
JDF's Avatar
JDF
And get charged out the @$$???!!! I think I'll pass on that one
Old Sep 19, 2011 | 07:41 AM
JDF's Avatar
JDF
I'll give that a look
Old Sep 19, 2011 | 07:43 AM
texastboneking's Avatar
Bear Eats King...
Bear ****s Bone
Confused here. Dying while running. Or dying while sitting?
Old Sep 19, 2011 | 08:10 AM
JDF's Avatar
JDF
Dying after sitting for a couple hours. Like while I'm working and then leave for lunch only to find out my battery has absolutely no juice at all. It'll work fine after a jump.
Old Sep 19, 2011 | 08:12 AM
Bear Eats King...
Bear ****s Bone
Parasitic draw. Disconnect the amp. If it dies still then its not that. If you really want to find it you will need a multimeter. Then I can tell you has to find your problem.
Old Sep 19, 2011 | 10:47 PM
JDF's Avatar
JDF
That's what I've been doing. I pulled the main fuse for my amp last Wednesday and have been drivin around just fine so that's the likely problem.
Old Sep 19, 2011 | 11:05 PM
polarisTXguy's Avatar
I had a 5.0 that was charging great and it still turned out to be a bad alternator. After completing a parasitic draw test we determined the alternator was causing the short. If we let the car sit more than about 12 hours the battery would be dead.
Just a thought
Old Sep 19, 2011 | 11:22 PM
JDF's Avatar
JDF
Hmm I'll have to look into that
Old Sep 20, 2011 | 03:33 PM
Onesickstang01's Avatar
Just a thought
Seen this many times. Had a fox mustang that did this to me also
Uofmrampage
Aug 2, 2022 02:55 PM
lakersfreak
Jun 13, 2022 12:29 AM
PonyMuscletang13
Sep 29, 2015 09:40 AM
PonyMuscletang13
Sep 26, 2015 02:33 PM
PonyMuscletang13
Sep 24, 2015 01:40 PM
