Awful Gas Mileage
Old 3/28/12, 08:52 PM
Bear Eats King...
Bear ****s Bone
texastboneking's Avatar
Originally Posted by bluethunderhorse
Quick way to check for a vacuum leak, is to spray wd40 around the mating surfaces. If you hear any change in the way the engine runs, in any certain place then you've narrowed your search.
Wd40!?!?
OP do not use wd40 unless you want a very oily intake/engine. Use brake clean or Carb cleaner as these willchange the idle without causing a nasty oily mess
Old 3/28/12, 11:46 PM
shaunrc's Avatar
What level is your coolant and how long does it take for your motor to heat up and if you aren't too sure check it out to see if it even gets to operating temp and let me know
Old 3/30/12, 03:36 PM
cntchds's Avatar
You're thinking tstat? I'm not sure exactly what temp the car is getting to but I can check.
Old 3/30/12, 07:31 PM
skunk21's Avatar
Originally Posted by texastboneking
Wd40!?!?
+1 on the carb cleaner. WD40 thats a new one
Old 3/30/12, 10:02 PM
cntchds's Avatar
The computer says 97 Celsius or about 205 Fahrenheit. Idle speed is at 700.
Old 4/2/12, 12:28 AM
shaunrc's Avatar
Yeah I was thinking tstat but its getting up to normal op temp what about overheating at all
Old 4/2/12, 01:21 PM
cntchds's Avatar
Nope. Stays steady at just over 200 independent of outside temp. I'm running a tank of 91 octane Chevron to rule out if it was just bad gas.
Old 4/3/12, 10:36 AM
benjyc32's Avatar
Is yours a gt? When I had my 01' it idled around 4,500-5,000... 8,000 is pretty high for you.
Old 4/3/12, 01:05 PM
1999Pony's Avatar
I think you need to remove a zero, or take your foot off the gas when your at idle.
Old 4/3/12, 01:11 PM
11SHELBYGT500's Avatar
If that's the idle would like to know the redline. lol
Old 4/3/12, 01:13 PM
1999Pony's Avatar
Especially if your idling at 8k
Old 4/3/12, 02:05 PM
benjyc32's Avatar
My bad, 450-500... it's been a long day in the blazing heat of Tn.. But I vacuumed the inside, washed, and waxed my car, and detailed my my motor bay and made everything shiny for the car show this weekend!
Old 4/3/12, 03:50 PM
1999Pony's Avatar
Haha its all good, just had to give you a little crap at least.
Old 4/3/12, 04:08 PM
benjyc32's Avatar
Ha yeah, I mind has been in 50 different places over the past week due to a concussion. So I may sound blazed.
Old 4/3/12, 08:44 PM
shaunrc's Avatar
How often do you run 91 octane a lot of people believe its okay to but the only time you want to run a higher octane is when you raise the compression ratio and there's no bad gas maybe a bad fuel filter restrictive fuel rails maybe a bad injectir
Old 4/4/12, 02:00 PM
mdelao's Avatar
The owners manual says that should use 89 octanes. Have you try before?
Old 4/4/12, 06:45 PM
cntchds's Avatar
Yeah, I usually run 89.
This was a first. Just to experiment.
Old 4/4/12, 08:31 PM
shaunrc's Avatar
Have you checked your coil packs to make sure they are all on secure I know it sounds stupid but sometimes those plastic caps break and the coil could lose its connection causing a hesitation or low fuel economy
Mpaps
10/11/17 08:06 PM
NC14GT
9/10/17 04:47 PM
mx5jhb
9/30/15 04:44 PM
MustangGTCS13
9/17/15 07:38 AM
Hristofor
1994-2004 V-6
9/11/15 12:05 PM
Quick Reply: Awful Gas Mileage
