AODE Tranny help!!!!!!
Old May 30, 2008 | 09:35 PM
future9er24's Avatar
almost there....
Old May 31, 2008 | 10:20 AM
edumspeed's Avatar
Legacy TMS Member Pr
FINALLY I'M OFF!!!!!
Now, to PARTYYYYYYYYYYYYYYYYY!!!!!!!!!
And to work on the crappy trans,
Old Jun 3, 2008 | 06:14 PM
bluethunderhorse's Avatar
Originally Posted by ravenblack67
I'm assuming you have a 4R70W. If that is the case, you are losing the forward clutch seal. The transmission needs to be rebuilt. Continuing to drive it will make things worse because the temp of the fluid goes way up when it slips. I would recommend a full rebuild, cooler flush, and a remanufactured torque converter.
94's had had the AODE. Sounds to me like the valve body might have a blown gasket
Old Jun 3, 2008 | 11:34 PM
edumspeed's Avatar
I'm suspecting that too. I'll try changing that to a newer version, along with the solenoids as well. On another forum I posted, some trans guys told me about the defects of that trans.
Valve body, oil pump stub shaft, solenoids and the overrunning clutch w drum, they said to upgrade to the 4r70w parts that bolt right in and are stronger 96 to 98, i think. With those upgrades they said the trans can support up to 400 hp with no problems. I'll take out the oil pan to take off the valve body and inspect it. If it's too much of a mess, then I'll take out the whole trans and rebuild it.
Wish me luck!
Old Jun 3, 2008 | 11:57 PM
Do you think it'll be cheaper to just replace the entire unit with a performance unit?
Old Jun 4, 2008 | 12:04 AM
edumspeed's Avatar
No, those cost about $2000 - $2500, more than what i paid for the car. I've already checked that.
Old Jun 4, 2008 | 03:13 AM
dang!
Thats too bad, coulda been fun. Any idea how much the repair process is gonna run you by comparison?
Old Jun 4, 2008 | 08:37 AM
edumspeed's Avatar
I'd expect $500-$1000, depends on parts prices and labor cost on things that need to be done with special tools I don't have, but my neighbor has them, so I wouldn't expect much on that also. I also want a good shift kit, to chirp tires on 2'nd at least.
Old Jun 5, 2008 | 01:40 AM
Chirping into second is alot of fun
Old Jun 5, 2008 | 07:54 PM
edumspeed's Avatar
Update
I went and used my last resort, Trans Magic. Have used the car for a day and the problem hasn't come back. I'll baby it to see what happens, and try to save some $ for the rebuild.
Burnhaven
V6 Performance Mods
Jul 23, 2015 11:57 AM
Rog13GTCS
Jul 19, 2015 02:46 PM
Burnhaven
Torch Red
12
Jul 18, 2015 11:41 AM
Kgilly
Jul 9, 2015 01:47 PM
maddhatteroo7
Feb 24, 2005 01:38 PM
