Sponsored by:
Sponsored by:
2015 GT Brembo brakes squealing
Old Sep 4, 2022 | 12:00 AM
kbontemps85's Avatar
Hi everyone, my 2015 GT with PP has 29k miles and about a week ago the brakes started squealing extremely loud. I have seen a few posts about it and was wondering if anyone had posted a solid solution to get them to stop without taking it to the dealership? Thanks!
Old Sep 4, 2022 | 07:13 AM
05stangkc's Avatar
Hello,
At 29k May Need Some New Pads! My 07 Shelby with Brembo's are Getting Close to Needing Replacing at 33K And Those Miles Were 90% Highway! But Here is the Ford Shop Manual Section on NVH for the Brakes!
Also Included 6 Piston Pad R&R. That is What you Have????
Anybody Out there With The Brembo's Got Any More Input Please Chime in!
KC
Symptom Chart: NVH
Diagnostics in this manual assume a certain skill level and knowledge of Ford-specific diagnostic practices.
REFER to: Diagnostic Methods (100-00 General Information, Description and Operation).
Condition Possible Sources Actions Vibration when the brakes are applied
  • Brake disc(s)/
  • Suspension components
Brake vibration/shudder — occurs when the brake pedal is released Brake drag REFER to Symptom Chart: Brake System Rattling noise
  • Caliper guide pins or guide pin bolts
  • Missing or damaged anti-rattle clips or springs
  • Loose brake disc shield
  • INSPECT the caliper guide pins and guide pin bolts. INSTALL new components as necessary.
  • INSPECT the brake pads for missing clips or broken springs. INSTALL new components as necessary.
  • TIGHTEN the brake disc shield bolts to specification.
  • REFER to: Brake Pads - Vehicles With: 2-Piston Brake Caliper (206-03 Front Disc Brake, Removal and Installation).
    REFER to: Brake Pads - Vehicles With: 4-Piston Brake Caliper (206-03 Front Disc Brake, Removal and Installation).
    REFER to: Brake Pads - Vehicles With: 6-Piston Brake Caliper (206-03 Front Disc Brake, Removal and Installation).
    REFER to: Brake Pads (206-04 Rear Disc Brake, Removal and Installation).
Squealing noise — occurs on first (morning) brake application Brake pads Acceptable condition. Caused by humidity and low brake pad temperature. Squealing noise — a continuous squeal Brake pads INSPECT the brake pads. INSTALL new components as necessary.
Squealing noise — an intermittent squeal Brake pads Acceptable condition. Caused by cold, heat, water, mud or snow. Groaning noise — occurs at low speeds with brake lightly applied (creeping) Brake pads Acceptable condition. Grinding/moaning noise — continuous
  • Brake pads
  • Brake disc
INSPECT the brake pads, brake discs and attaching hardware for damage. VERIFY brake components are within specifications. INSTALL new components as necessary.
Removal
NOTE: Removal steps in this procedure may contain installation details.
  1. Remove the wheel and tire.
    Refer to: Wheel and Tire (204-04A Wheels and Tires, Removal and Installation).
  1.
    1. Remove the 2 brake pad pins.
    1. Remove the brake pad spring retainer clip.
    1. Remove the brake caliper pin bolt.
      Torque: 22 lb.ft (30 Nm)
  1. Compress the brake caliper pistons using a brake pad spreader tool.
  1. Remove the brake pads.
Installation
  1. NOTE: If installing new brake pads, make sure to install all new hardware and lubricant supplied with the brake pad kit. Refer to the brake pad instruction sheet when applying lubricant.
    To install, reverse the removal procedure.
  1. Depress the brake pedal, check the brake fluid level in the brake fluid reservoir and top up as necessary with brake fluid.
    Refer to: Specifications (206-00 Brake System - General Information, Specifications).
Old Sep 5, 2022 | 06:13 AM
Bert's Avatar
yep, probably pads need to be replaced; they have little squeelers on them to make that noise to warn you that it is time
the older Brembo pads were super dusty, not sure about the newer ones, but this might be a good time to look in to different pads if that bothers you
good news is, the Brembo's are super easy to change
Old Sep 9, 2022 | 04:52 AM
shaneyusa's Avatar
Agree with both. That is my first thought on the sudden extremely loud squeal. Time for new pads...
Old Mar 14, 2023 | 03:08 PM
bikewrnch's Avatar
Yes I did have that very problem. Took it several places and heard some of the worst
I am an ASE Master L1 Master technician w/40 some odd years experience. I have been either a shop foreman or head tech that had to resolve a load of problems that others couldn't fix .
. Anyway, 1 bought my 15 Mustang GT w/24000 miles .
oh also had premium w/pp .
My car started squeaking a month or so after I bought it .
I talked to several Mustang ofencianodos about and no great answer. I then looked up
For service and recalls . I found a recall of my very problem. When i took it to the dealer (reluctantly) they told me my car didn't fit the service buliten . I had the 6 piston Brembos.
. Now you have to remember that I had found and fixed thousands of little squeaks and big bumps also . IT DROVE ME CRAZY to hear this squeaking noise . Finally I took my Mustang to the dealer for one more chance and low and behold there it was . They found the bulletin.
They installed 2 front rotors, pads and everything that was on the bulletin. Since then quess what ? NO MORE SQUEEKS ! SORRY FOR THE LONG STORY . BUT YOU KNOW WHAT ? I
It could of been a lot longer !
Old Mar 14, 2023 | 03:23 PM
Bert's Avatar
Originally Posted by bikewrnch
..... I took my Mustang to the dealer for one more chance and low and behold there it was . They found the bulletin.
They installed 2 front rotors, pads and everything that was on the bulletin. Since then quess what ? NO MORE SQUEEKS ! ....
so -- there is a TSB (Technical Service Bulletin) for squealing/squeaking on the 6-piston Brembo brakes?
Can you post the TSB number? That would be very helpful for people who have this problem in the future.
thanks, and welcome to the forum
Old Mar 14, 2023 | 03:40 PM
m05fastbackGT's Avatar
I'll second that!
Old Mar 14, 2023 | 05:28 PM
05stangkc's Avatar
I think He Is Saying That The 6 Piston Were Not Listed But they Used The Available Information on TSB for the 4 Piston Brakes and Replaced Those Same Items. Here is the 4 Piston TSB. So They Would Replace 6 Piston Pads & Rotors. If I'm Wrong No Harm No Foul Good Info!
KC
File Type: pdf
V6 Driver
Jun 9, 2015 11:30 AM
firstang001
Jan 21, 2015 12:11 PM
TheReaper
Aug 7, 2014 07:45 AM
GT40 2
Jun 19, 2014 08:33 AM
