Sponsored by:
Sponsored by:
2015-2023 Mustang Which motor oil is everyone using?*
Old Oct 17, 2018 | 03:21 PM
  #41
Gabe's Avatar
Originally Posted by area5179
Darcman might be on to something. According to my 2019 GT Owner's Manual under track use (pg 248):
5.0L: Prior to the track event, drain the
engine oil, replace the oil filter and
change the engine oil to 5W-30. After
the track event, drain the engine oil,
replace the oil filter and refill the engine
oil with 5W-20. I would assume that using the 5w-30 during track use would offer better lubrication because of the hard use usually seen on a track.
And that same owner's manual probably mentions that warranty coverage doesn't apply to repairs needed/caused by track use.
So 5w30 might provide better protection during track use, but my comment above was all related to warranty coverage.
I was a Ford Service Advisor for 9+ years. I've had to ask people for oil change receipts.
Old Oct 17, 2018 | 07:16 PM
  #42
5.M0NSTER's Avatar
And the Track Pack as well as PP1 cars of the newer vintage feature 5W-50 oil due to better film strength and thus better protection during hard use. Fact that they also have oil coolers further promotes thicker oil.
I have used W20 and W30 interchangeably for years in my other cars. Do what you think is best. It's your engine.
Old Oct 18, 2018 | 01:21 AM
  #43
guyr's Avatar
Originally Posted by typesredline
Penzoil platinum ultra. Hard to find. But the best oil around imo.
Second the Pennzoil Platinum recommendation. I have a V-6, so I went with the plain Platinum rather than the Ultra. Walmart sells both products at incredibly reasonable prices. My previous oil change I went with Mobil 1, recommended by the service place I used. I was shocked at how quickly the oil life remaining indicator plummeted on Mobil 1. After about 4000 miles, it was down to 10%! So, after reading that Pennzoil Platinum had a reputation for keeping engines clean, I switched to that. I've now put about 4000 miles on that, and the indicator says I still have 53% remaining. The oil on the dipstick still looks clear and clean. So, I'll be sticking with Pennzoil Platinum from now on.
Old Oct 18, 2018 | 07:54 AM
  #44
Bert's Avatar
. . . . I would assume that using the 5w-30 during track use would offer better lubrication because of the hard use usually seen on a track.
As I understand it -- the "30" in 5W-30 represents the oil viscosity when it is hot; basically means that the "30" is more viscous when hot, than the "20" . . . this means that the oil film is harder to break through and cause metal-to-metal contact, without the oil in between. So it makes sense that you would want that under extreme conditions like on a track; where the oil is going to get very hot, and in addition you are also putting very high loads on all of the components in the engine.
That higher viscosity also means there is a bit higher friction, which reduces the fuel efficiency (and also the power output) a little bit.
For normal duty, when the oil is not going to get that hot, and you are not putting those extreme loads on the engine components, the "20" should be fine.
Old Oct 18, 2018 | 02:18 PM
  #45
Gabe's Avatar
There are two arguments going on.
I'm talking about warranty coverage, you're talking about what's better for track use.
I voided my warranty a long time ago when I installed the Whipple.
Doesn't mean that I can't offer advise to others on how to keep their warranty coverage.
Originally Posted by guyr
Second the Pennzoil Platinum recommendation. I have a V-6, so I went with the plain Platinum rather than the Ultra. Walmart sells both products at incredibly reasonable prices. My previous oil change I went with Mobile 1, recommended by the service place I used. I was shocked at how quickly the oil life remaining indicator plummeted on Mobile 1. After about 4000 miles, it was down to 10%! So, after reading that Pennzoil Platinum had a reputation for keeping engines clean, I switched to that. I've now put about 4000 miles on that, and the indicator says I still have 53% remaining. The oil on the dipstick still looks clear and clean. So, I'll be sticking with Pennzoil Platinum from now on.
Mobile is a town in Alabama.
Mobil is a brand of oil.
Old Oct 18, 2018 | 02:57 PM
  #46
guyr's Avatar
I guess Alabama doesn't get a lot of mileage out of their oil.
Thanks, posted when I was very tired.
Old Oct 18, 2018 | 03:38 PM
  #47
Gabe's Avatar
I've gotten more mileage out of that "joke"
Old Nov 9, 2018 | 05:30 PM
  #48
MrGreyNJ's Avatar
I use Quaker state full synthetic but doesn’t seem like many people use it on here, saw a whole lot of other brands.
Old Nov 26, 2018 | 12:25 AM
  #49
Lime GT's Avatar
Castrol Conventional 5w20 is what I'm using but my car is only 3 season driven.
Old Nov 26, 2018 | 07:57 AM
  #50
Bert's Avatar
. . . . I was shocked at how quickly the oil life remaining indicator plummeted on Mobil 1. After about 4000 miles, it was down to 10%! So, after reading that Pennzoil Platinum had a reputation for keeping engines clean, I switched to that. I've now put about 4000 miles on that, and the indicator says I still have 53% remaining. . . . . .
My understanding is that the oil life meter does not sense the quality or condition of the oil in any way; rather it records things that affect the life of the oil, such as miles driven, length of driving time, time that the oil is up to temperature, length of time since last change, etc . . . . so there is no way it can tell the difference between the two oils.
So my guess is, there had to be something else going on -- for example if the 4000 miles on Mobil 1 was over the winter, I think it might have been tripped by the elapsed time (I think it recommends an oil change every six months? I have noticed this when I take my car out of storage in the spring)
If anyone knows different about the oil life meter, please correct, thanks
Old Dec 18, 2018 | 12:03 PM
  #51
rockthe60s's Avatar
I agree. As long as my GT is under warranty I will use 5W20 and the motorcraft filter. After the warranty, things may change.
Old Aug 6, 2020 | 07:03 PM
  #52
micronpr's Avatar
i use 5w-30 Full Synthetic Mobil 1
Old Aug 6, 2020 | 07:34 PM
  #53
SpectreH's Avatar
At 111,000+ miles, still using the factory recommend oil in my '13 GT.
Old Aug 15, 2020 | 05:54 AM
  #54
Gabe's Avatar
Old Aug 15, 2020 | 11:54 AM
  #55
I'm too lazy to look it up but I used to always use AmSoil. When I bought my Boss they didn't offer 5-50 so I use Ford synthetic 5-50.
Old Apr 30, 2022 | 07:26 AM
  #56
Grayghost5.0's Avatar
Mobile 1 full synthetic 5w30, looking to move to 5w50
Old Apr 30, 2022 | 07:28 AM
  #57
walmart 27$ for a 5 Qt jug of Mobile 1 full synthetic, and ditch 5w20 ...either go 5w30 or 5w50 .... 5w20 is too light of oil for these engines.
Old Apr 30, 2022 | 11:37 AM
  #58
houtex's Avatar
Welcome to the forums, you proliferic poster you!
In regards to the higher weight oil you recommend... the problem with that is temperature, use and engine design may not like it and may in fact reduce your MPG. I'm sure everyone cares about that MPG these days with Premium gas bein' what it is...
In any event, 30 is one thing... and even then it's extremely circumstantial and may actually be harmful... but 50 is right out. The variable cam phaser system won't like it, and the engine will have to work harder to pump that oil around... and if it can't get the oil around, then your engine will die, horribly. Tolerances of the bearings, pump, all of it are not going to like that 50 weight.
Also food for thought: after takin' apart my 4.6 3v, which is admittedly not exactly the same as the 5.0 Coyote but similar enough, and seeing what regular use of synthetic 5w20 changed every 5000 miles on a daily driver at 183K at the time? Yeah. 5w20 is perfectly fine and called for in these engines. My engine was dang near perfect in every way. Stupid plastic timing covers and bad tensioners is the design problems, not oiling. The car is still runnin' strong to this day, so far, and while I wound up getting a beater Caliber to run around (it was too good to pass on), she's only got to 186K now. Still, that engine was excellent inside there. For what that's worth.
But you do you. And I hope you don't experience issues. Good luck!
Old Apr 30, 2022 | 12:22 PM
  #59
Well what motor are we talking about? Because I know in 2021 ford switched their recommended oil for the 5.0 to 5w30 and in fact my oil fill cap says 5w30 from the factory. 5w50 is what the gt500s are running but many coyote drivers are switching to it as well…. And I do see the temp concern if you’re living in a area where it gets severely cold … but for these high performing motors it needs that extra viscosity. I think even 5w30 is too light for these motors to be honest
Old May 1, 2022 | 06:38 PM
  #60
m05fastbackGT's Avatar
Just a heads up! Rather than submit double posts, you can always edit a post by selecting the Edit tab, located below on the right hand corner.
Rasn1320
Feb 19, 2018 06:59 PM
Muscle-Car-Memories
Mar 12, 2013 07:42 PM
tu3218
Aug 31, 2012 05:26 AM
spitfire760
Apr 5, 2012 05:02 PM
ucdavisboy
Feb 10, 2005 08:24 AM
