What are Coil Overs?
Started out looking for lowering springs to close some of the wheel gaps trying to achieve better looking stance, and then Shocks & Struts - Eibach, FR Handling kit, Steeda, Koni, Koni, and Koni. Now, I have finally reached at Coil Overs.
There's one problem though. What are they? I ask because from my search, most seem to ask for springs or shocks/struts recommendations but not many coil... these.
My short understanding is that they are shocks/struts 'over' coils (springs) as a package. If so why do you ask about springs n shocks/struts separately? I'm such a noob.
Coilovers are shocks/struts with the springs mounted directly onto them. And the race type coilovers use a small diameter lightweight spring and most have an adjuster nut setup that allows ride height adjustment.
Your front struts are a type of coilover, just that they use larger heavier springs than race type coilovers and aren't ride height adjustable.
I would only look at coilovers if you are looking for a very aggressive drop and still want a good ride, with coilovers you can basically get any stiffness of spring to match what you want to do. I wouldn't say all coilovers are race track ready either since there are some very cheap options out there. Depending on your drop the best thing to do would probably be going with conventional springs and shocks/struts. You also have to think about what else you should replace when lowering because that will increase the cost quite a bit.
Yep, definitely not for me
^^ As a Boss owner... I like mine... but I have NO idea of other suspension set-ups other than my '12 base GT and my brothers old '05 Saleen S281.
The boss suspension is adjustable as far as stiffness goes... not height.
Ok so Bosses are adjustable... are they the same ones from Ford Racing?
Hit up Jayman33 on here and see what he can do as far as pricing goes, he is a great guy to deal with and has some great pricing.
http://shop.hypermotiveperformance.c...ntrol_c488.htm
The Boss shocks/struts are good for what they are but I feel like the car should have come with Koni's from the start.
We've ran BC, Ground Control and are now running AST on our 13 Boss for our time trials here in Germany. AST is a bit rich for someone just wanting to do a weekend warrior thing but the ground control Coilovers are by far the best set I have ran in this price range. For 1600 shipped these come with custom dampened Koni's and koni inserts, Eibach race series springs and Ground control CC plates.
You can also get the front bodies custom powder coated too
Awesome, awesome setup!
We've ran BC, Ground Control and are now running AST on our 13 Boss for our time trials here in Germany. AST is a bit rich for someone just wanting to do a weekend warrior thing but the ground control Coilovers are by far the best set I have ran in this price range. For 1600 shipped these come with custom dampened Koni's and koni inserts, Eibach race series springs and Ground control CC plates. You can also get the front bodies custom powder coated too
![Heh](https://themustangsource.com/forums/images/smilies/heh.gif)
