Revised TSB for Lower Control Arm squeak
#243
Finally got my LCA's taken care of. I've been procrastinating but called the dealer last week and scheduled the appt for this morning. I am fortunate enough to have about 7 ford dealers close to me. I chose the second closest which was just torn down and rebuilt. It's gorgeous.
Initial phone convo was good. The service advisor said they had kits in stock and do a couple a week. I told him I was nervous about going to the dealer and he offered to have me stay with the tech durning install. He also said I could drive it in. So they were very accommodating to say the least.
When I got there this morning I pulled up, locked the car and saw my advisor. He was finishing up with a customer but promptly came out and clearly remembered me and what we had talked about. He talked to the tech and came back to lead me in the shop as I drove. I pulled it on their brand new racks and met the tech Will.
He was extremely cautious with every movement he made. At first I was thinking that it's because I was standing right there. But after talking to him I realized that he was always like that. I told him that I was worried about the wheels scratching when coming off. He said that's bc some techs don't hold the wheel on the last lug. He then swapped the LCA's in no time.
I backed it off, he told me to drive it and see if the wheel was straight. I came back bc it was a bit off. I pulled it on the alignment rack which used the brand new style Hunter pieces that clamp on the tire itself and don't damage the wheel. Before I knew it, the alignment was done and perfect.
As for the new lca's, I am crunch free and it feels firmer over speed bumps as well.
Deysha, shout out to Elder Ford in Tampa. Will and Johnny were awesome!
#244
#245
I'm Crystal, I'm helping out here while Deysha is out of the office. Let's get this awesome feedback documented! To make that happen, send me a PM with your full name, best daytime phone number, dealer info, and any specifics you'd like me to include. Leave the rest to me.
Crystal
#246
Johnny is the advisor but I think he spells it differently. Johany maybe? Will was the tech. The new arms are the D variety with the heat shields from the 13-9-3 TSB.
#247
How close are you to the warranty? I'm at 32K and won't be back in the states till this summer with my car. They should still do the TSP even though I'm out of warranty correct?
#248
Feb of 2016 it'll be up. Only have 9k miles. I'd imagine that being out of the country, they'd make some sort of exception. But idk. I think it's still warranty based.
#251
Also, remember most paid repairs done at a Ford Dealer come with a 24 months/unlimited miles warranty. You can schedule an appointment online here.
Deysha
#252
hi Deysha i have the same problem with my 14 gt with 17k only the problem is am in UAE and the dealer do not carry on with the guarantee because my car is us import
so what i can do to fix this problem.
thank you
thank you
#253
Also, I know we’ve made arrangements with the Overseas Military Sales Corporation (OMSC) to assist with service-related issues. OMSC can help you find a participating service center. Please contact them at 1-800-669-6183 or 9-011-49-6173-704-256. I hope this helps.
Deysha
#254
hi Deysha thank you
as i told you acalled them and they dont want to listen they say its not their problem and for the second number u gave me i dont see what they can do for me.
#257
Have you addressed this with your Ford Dealer, alfaromeo? Your service manager is in the best position to ensure a proper diagnosis, and will be able to provide available options and/or coverage for any work needed.
Deysha
Deysha
Thanks Deysha. I am pretty sure it is the exact same problem since I have experienced same thing for several times.
My dealer is awesome. But they can't help in case of out of warranty. I can only blame Ford design and quality.
#258
Deysha
#259
Hi Johani
They should, Ford warranty is international. I imported my car from US and in Saudi Arabia the dealer honored the warranty and they changed the LCA 4 times and that didn't solve the issue. And now I'm looking for aftermarket LCA.
Regards
#260
Had this issue on my GT a long time ago. It got repaired under TSB 12-8-24 and the squeak went away. The noise came back a few weeks ago. Checked online and saw that there's a new TSB (13-9-3) out that added shields. Scheduled my car to bring it into a dealer recommended to me by some Mustang friends to get it replaced. Just got the car back - and not even 50 miles later, I'm going down the road with the windows open and "squeak squeak squeak squeak squeak squeak" over every little bump.
I let the car cool down and put her up on jackstands to have a look. The control arms look new (clean, although some chips and scratches, correct part number with -D suffix), but the shields called out in the drawing are clearly missing so I'm not sure what the dealer did or didn't do. If all the dealer forgot to do is install the shield, it still doesn't explain why brand new bushings are this bad.
![Name: 6ZkTHMm.png
Size: 162.1 KB](https://themustangsource.com/forums/attachments/f821/214176d1683055566-revised-tsb-lower-control-arm-squeak-6zkthmm.png)
![Name: fzUNVDWl.jpg
Size: 57.5 KB](https://themustangsource.com/forums/attachments/f821/214177d1683055566-revised-tsb-lower-control-arm-squeak-fzunvdwl.jpg)
![Name: dTwJAtIl.jpg
Size: 34.4 KB](https://themustangsource.com/forums/attachments/f821/214178d1683055566-revised-tsb-lower-control-arm-squeak-dtwjatil.jpg)
![Name: X6ocUSLl.jpg
Size: 55.6 KB](https://themustangsource.com/forums/attachments/f821/214179d1683055566-revised-tsb-lower-control-arm-squeak-x6ocusll.jpg)
So now I have to take the time to go back to the dealer and get this figured out. This is getting a little frustrating.
![Name: 6ZkTHMm.png
