How big is too big (tires)?
Old Jan 24, 2017 | 03:33 PM
toneofjustice's Avatar
Looking to get a new set of rims/tires for my 2013 GT w/ Brembos. I like the idea of staggered to get some meat down in the rear but don't have much experience picking wheel/tire sizes. 10" wide rims in the rear would be cool but is all the offset to the outside? I don't want to have to put mudflaps back there to keep my paint from getting chewed up. I'm looking keep the diameter @ 19". Not looking to get extreme, just put some fatter rubber down.
From researching other threads maybe this size is a good combo? 19x9 wheels up front and 19x10 in the rear. 245/45 front, 275/40 rear.
Old Jan 24, 2017 | 06:47 PM
5.M0NSTER's Avatar
You can go as wide as 275/35 or 275/40 on the brembo car 19x9 wheel.
Other than looks, what's your goals for the car? Putting a wider tire in the rear will change the handling characteristics more towards understeer. You can fix that with a meatier rear sway, but if you mainly drive on the street you probably don't need to worry about it too much.
You can go as wide as 295/35-19 on a 10" rim if you so choose.
On the other hand, you can get square 275 setup on all 4 corners. It will help your launch, and maintain the neutral-ish handling balance, while allowing you to rotate for proper wear.
Old Jan 25, 2017 | 09:55 AM
My goal is to increase traction in the straight line.
Old Jan 25, 2017 | 05:56 PM
Rog13GTCS's Avatar
What Monster said about the 295 on a 19x10. I have 19x10 and have a 285's on them. There are some 10.5 and 11's widths that will fit in the rear with the right offset.
Old Jan 26, 2017 | 10:24 AM
Do the tires stick out much more than stock? Any chance you could share a pic of the rear of your car? Also what offset did you use?
Old Jan 27, 2017 | 07:07 PM
Rog13GTCS's Avatar
Look at this link Scroll down. I'm the Blue GT/CS. My rear offset was a little to aggressive. Mine is 38, but it should have been 40, so there is a little poke from the rear.
"Sticky" summer rubber will help with traction, and the extra width helps too. I'm running the Bridgestone Pole Position. They are harder to break free than the stock Pirelli's were. Look at the summer tires on Tirerack. The Michelin Pilot super sports are highly regarded, but on the higher price wise.
Old Jan 27, 2017 | 09:42 PM
Old Jan 27, 2017 | 10:13 PM
I was gonna say 35's are probably a little too big
Old Jan 28, 2017 | 09:19 AM
5.M0NSTER's Avatar
That looks like a cartoon car!
Old Jan 28, 2017 | 09:23 AM
5.M0NSTER's Avatar
Glad you've been linking your S04s! I was quite happy with them too.
I just purchased the replacements. I went up one level to extreme performance summer category this year to get more ultimate grip at the track. Ventus R-S3s. Killer deal on Tire Rack. Only $126 each in 275/35-19
Attached Thumbnails How big is too big (tires)?-img_0156.jpg   How big is too big (tires)?-img_0158.jpg   How big is too big (tires)?-img_0157.jpg
Old Jan 28, 2017 | 11:18 AM
EF1's Avatar
EF1
These are too big... Attachment 182591
That is funny they managed to transfer the wheel gap from the back to the front.
Old Jan 29, 2017 | 06:15 AM
Gabe's Avatar
19x11 would fit great in the rear with offset in the 57-63mm range, and then you could do a 315/35/19 tire
When doing different wheels, it's all about the offset.
Old Jan 29, 2017 | 08:54 AM
sakol's Avatar
You can do 275/40/19 square set up...probably the biggest that works for both front/rears.
Old Jan 30, 2017 | 04:30 AM
Gabe's Avatar
19x10 in the front is a great size, you can then run 275/40/19 or 285/35/19 and you'd have a great fitment on the 10"-wide wheels.
In the back, like I posted above, the widest you could easily go is 19x11, and you could then do a 305-315 rear tire.
The offsets on both fitments will need to be specified properly or you might have problems.
This is a 48mm-offset 19x10 wheel with a 275/40/19 tire on it on the front of my Track Pack '13, with plenty of caliper and strut clearance:
Rear fitment on the pic above is same wheel but 20x10, same 48mm offset, with 305/35/20 Nitto NT555 drag radials.
Both set-ups right after they were mounted/balanced:
Old Jan 30, 2017 | 05:49 PM
Rog13GTCS's Avatar
That was a killer deal. Let us know how those work this summer.
Old Apr 1, 2017 | 04:19 PM
I found a sexy 19x9.5 set i want to pull the trigger on. they come in 35,40, and 48 mm offset.
Anyone know if a 19x9.5, 40 mm offset will work on front and back?
Old Apr 1, 2017 | 04:31 PM
Gabe's Avatar
That should work perfectly.
What size tires are you contemplating for those?
Old Apr 1, 2017 | 05:57 PM
ElkGroveFordGuy's Avatar
I run the SVE drift rims 19x9.5 with a 285/35/19 on all 4 corners.
Fits perfect no rubbing at all with steeda sport springs.
Old Apr 1, 2017 | 08:09 PM
Get the 35. With a 9.5, these cars can really run a +30. I had 19x9.5 +35 all around with the stock 255/40 tires and they were still too tucked for me. I put 1/4" spacers up front and 5/16" in the rear. 1/4" is about 6.5mm and 5/16 is about 7.25mm, making the wheels +29 front and +28 rear. The 255/40 was a little stretched on the 9.5, so if you were to run 275 or 285/35, they'd be perfect on the 19x9.5 +35.
Old Apr 1, 2017 | 10:57 PM
