Two lines of thought...
1. Does anyone know for sure if 155 is truly the top speed? That has to be electronically limited. Car has the gear, power and aero to go much faster.
2. How many are planning to basically leave their Boss alone, at least initially? Considering the non-LS outran an M3 and an Audi R8 at Laguna in MT's latest track test, the car sure sounds well sorted-out. As much as I want to mod, there is this part of me screaming "leave it the hell alone until you know first-hand what it can do."
Except for changing out the headlight bulbs to brighter H-13's, I'm leaving it alone....suspension and performance wise. I have a track car already.
I've done the "modify this and swap out that" route with Porsches and MINIs............you're never done!
Drive it and enjoy it..................factory engineered, built, and tested.
I'm leaving it as it comes from the factory, except adding TracKey, front splitter and brake ducts. So, pretty much 'stock'.
Seeing that cloud9 hits 160 in his GT500, he'd be one to discuss the 155 limiter question.
My concern is if you run a smaller track wheel, are you lowering it even further than 155 due to the speedometer reading higher than you are actually travelling. Another benefit of an aftermarket tune is the handheld tuner allows you to correct for these changes. We are just going to have to wait and see what the aftermarket tuners offer. It could be something as simple as asking them to turn off certain parameters. e.g. If some people opt for an off-road X pipe, they'll need O2 sensors shut off. My guess is you could just order a tune from a tuner that turns off the speed limiter in the TracKey tune and leaves everything else alone.
Thanks for the replies - that's what I thought on the speed limiter.
I do as well plan on pads, brake fluid, tires and the Boss goodies you mentioned like the brake duct coolers and trans scoop. I will wait on the splitter until someone else finds out definitively how much of a PITA it's gonna be taking it on and off at the track :-P
my two lines of thought go like this...
1. for the street: I wouldn't need any more performance, I'd just want the darn stance issue resolved. ie. lower the car a bit.
2. for the track: suspension modding all comes down to stuff that inspires confidence. won't know until I try the car as is. I'm inclined to go with they gave us. a related point - when it comes to mods for the track, I go back to old wisdom that says the order in which you mod for the track should go something like this:
1. safety
2. brakes
3. safety
4. brakes
5. safety
6. suspension
7. power
and on power, it power-to-weight that matters. adding power only helps in one direction, subtracting weight (or adding lightness, as the Lotus guys like to say) helps in all directions...forward, braking, cornering, everything.
Seeing that brakes are also a safety item (and the fact that it's the only weak link we know of on the boss...and any street car that's tracked hard, for that matter)...seems that that's the right place to start.
1. safety
2. brakes
3. safety
4. brakes
5. safety
6. suspension
7. power
Outside of that I will be doing a spoiler, louvers and other small appearance type work but not being a true racer I will leave the rest alone for now. There is nothing wrong with leaving it alone, Ford did a great job on this car.
http://www.sylvania.com/ConsumerProd...lacementGuide/
1. safety
2. brakes
3. safety
4. brakes
5. safety
6. suspension
7. power
1. safety
2. brakes
3. safety
4. brakes
5. safety
6. suspension
7. power
9/8/15 10:45 AM
