TrackDay ButtonWillow 105 Degrees
#201
1 Post
It dried out fortunately and car handled great. Chopped another 0.73 seconds first session out today. I'm down to 1:52.48. My buddy that came up with me in his C6 Z06 with coilovers making 503 at the tire runs 1:51s on R6s and he can drive "flat out" Haven't hit the bottom of the well yet I guess. Man I wish I had TracKey...the only thing I'm short on right now is power......temps are in the 220s with ambients in the high 70s. It's going to be hot this afternoon again so we'll see.
#202
Some 302R setup information posted over on mustangforums.com http://mustangforums.com/forum/5-0l-...t-weekend.html
Interesting data point about the external oil cooler and stock Boss 302 radiator.......
I wish Ford would have included some of this information in the Owner's Manual - 2012 Boss 302 Supplement. Transfering their experience gained at the track while developing the car would be valuable now as we try figure out the best cooling solution.
07-15-2011, 09:28 AM #1
FWP!
2nd Gear Member
Garage is empty, add now
Vehicle: 2011 Mustang GT
Spoke with Mark Wilson from Ford Racing last weekend
Was out at Laguna Seca last weekend for the Continental Tire and Grand Am series races (taking photos) and got in on a tour with Mark to see some of their BOSS 302R's there. Basically they have had two cars that started everything, the white/red/black #16 and the all orange #15. Couple interesting facts..
1 - The 302R's are bought right from Ford and are built and assembled (aside from the roll cage and seam welding) right next to their normal assembly line. They're built on a separate line called the prototype line where they spend 45 minutes to an hour at each station instead of 30 seconds.
2 - They cost $125,000 as a rolling chassis, engines are $14,000. Compare that to their rival Camaro's which cost $235,000 and engines are in the $45,000 range.
3 - The engines are factory stock down to the exhaust manifolds, they're taken right off the assembly line, one goes into a showroom stock BOSS302, next one goes into a BOSS 302R. The engines are then sealed (sealed bolts on the valve covers, front timing cover, and oil pan). The #15 and #16 have been running the same exact engine with no problems since they started the program in January of 2010!!! Most of the other cars in the field get their engines yanked out after each event and torn down.
4 - Transmission is a built up 6060 with the MT82 bell housing, but because the 6060 is a different size they figured out they could use the tail section off of the Australian Ford Falcon to make everything line up for the shifter to come up through the tunnel at the right spot. He highly recommends installing "the kitty litter scoop" to help cool our transmissions..
5 - Other modifications: Remote oil filter and cooler, rear diff is stock 3.73's with the torsen LSD but with a cooler setup and dual radiators, fuel tank removed and fuel cell installed in the trunk, gutted interior except for the dash which has to be stock (although lightened from 26 to 6 pounds), Ford racing ECU, stock BOSS 302 radiator, Ford racing exhaust, Brembo race brakes in the front only (rears get better pads only), Koni coil over's at each corner and the tiny stock rear sway bar, BBS wheels, stock electric steering, ABS module has been upgraded and is actually available to buy at Ford as of two weeks ago (apparently much better than even the stock BOSS 302 unit), all seams are welded before the full high-strength cage gets welded in, and some other small stuff...........
............Mark also mentioned that the pickup sensors for the TiVCT and a few others are meant to work properly at higher RPM's, they're different than stock.
FWP!
2nd Gear Member
#203
1 Post
How are you coming with your air to oil cooler? Looks like that's the route they took. Really anxious for yours and Johns results with his radiator.
It was 90F ambient at BIR this afternoon and the Boss ran STRONG. ECTs peaked in the 246F range, but recovered quickly when you shifted and dropped RPM. They would almost instantly drop 10-12 degrees every time you shifted. Amazing. That's actually a good sign that the cooling system is effective. I think it's really just a tweak. I'm really thinking John's higher capacity all aluminum radiator is going to do it, but we'll see after next week.
The Boss really earned a lot of respect at the PCA event. I had so many people coming up and asking what mods I'd done to the motor. None. What suspension mods have you done? c/c plates, otherwise None. A couple guys commented about how they could understand a Mustang maybe running them down in the straights but were shocked to get reeled in in the twisties as they put it. I had a corner worker who was working on credits for SCCA come over and chat me up for quite a while. He said with a Eastern European accent "this car is monster"
I just want Ford to know that despite some tweaks for serious track duty, this car is unbelievable. Most people were shocked that it only cost $43k when it's running with $130k GT3s. Thank you for building the Boss Ford
#204
#206
Attaboys to Gary for representing Ford!! Thanks for keeping us informed. I bet there's a lot of guys driving home wondering what else they could have spent that ninety grand "ADM" on that they paid!
#207
So it looks like your drilling did help a little.
#209
I am still waiting on the parts to come in. Rehagen did not have all the pieces in hand when I ordered their kit. Maybe it will ship out this coming week. I won't get an opportunity to install the kit until the 4th week of August, first three weekends already spoken for.
#210
beers
#212
#213
The #16 Multimatic Boss blew a motor at Watkins Glen. Roush blew a motor at Laguna Seca. Per the following document, Boss 302Rs running in Grand-Am are now permitted to have a Many connecting rod:
Technical Bulletin #2011-10
#214
1 Post
Sorry no video, but I just found some pics posted up from the event:
https://themustangsource.com/f813/ra...1/#post6115448
#215
Originally Posted by GT_350
Well maybe not so much after this......
#216
#217
Looks like the springs aren't able to remedy the brake dive issue. Oh well.
#218
1 Post
No but the front tires bite really well on turn-in. I was worried about it at first too but seems to work. Rear end can wag a bit under heavy braking but didn't seem as bad with the wing last weekend.
#219
This may be info you already know…Front brake dive displacements are a combination of front spring rate and rear suspension geometry. The Mustang rear axle has an upper control arm that pushed the rear of the car up when braking…the rear axle wants to rotate forward and the upper control arm is the holding force. The upper control arm is oriented in an upward incline from the differential housing to the body. The harder you brake, the more the back end lifts. One solution option for flatter braking…rear torque arm
#220
1 Post
I have one on my GT500, but it's heavy. Not sure the net effect +/- as it went on with coilovers and a Watts link at the same time. Overall my handling and lap times improved, but by how much per part, I can't say.
