Track wheels and tires
#62
Caster adjustments are done at install as they are not usually (ever in my experience) something you adjust at the track. Dropping the strut down will be required for this. MM will allow you to adjust caster from the top.
Vorshlag Link
Maximum Motorsports Link
#63
Must mean just the caster then.
#64
I've run both. I have Voshlag plates on my car right now.... There are pro's and con's to them as well as the MM's (and every other one). Camber is not easily adjustable, but they use a bigger bearing. That said, they aren't stone quiet---but no camber plate is, and I don't much care considering I also have a watts link with 4 rod-ends.
My car is about winning stuff, which it has done in both Stock and Street Prepared. And I plan on doing the same come the ProSolo Finale next month. Either way I'm in a Corvette for Nationals. Just kicking that out in case someone wonders why the switch, I committed to that ride in Super Stock early this year for Tours/Nationals.
#65
On the Vorshlag plates, you loosen the top four bolts (metric) and slide the plate in or out with the front corner jacked up in order to adjust camber. Jacking up the front corner unloads the strut and makes it easier to slide (just like MM).
Vorshlag Link
Vorshlag Link
Dave
#66
Yup. Sorry. Spoke with Terry and ya'll are right. There wasn't enough room in the strut tower to make the plates like the BMW plates My bad.
On a good front... he does have photos of the D-Force 18x10 posted:
D-Force 18x10 in S197 fitment
#67
For the track, I was thinking about getting a GT500 18x9.5 wheel/tire package with a staggered setup for tires (Nitto 555 255/45 front, 285/40 rear).
http://www.cjponyparts.com/ford-raci...5-2011/p/W187/
Anybody have experience with these tires? Will these work well for HPDE sessions?
#68
Longevity should be ok, and its great to progress from those to the NT05 to the NT01 as you move up (should you want to try the tires, each one is a step up from the previous in terms of grip, gives a great idea of how to drive each tire type).
#69
TOTAL NEWBIE dumb question time...with my LIMITED computer skills I did a little research on the Nitto site and they list the NT tires as Drag Radials...Is there a different tire y'all are referring to or are these good for track days and road course applications as well? Sorry to sound so ignorant..but I guess I am and my lack of knowledge on THIS type of racing/driving shows!
#70
Nitto 555R Drag Radial
Nitto 555R II Drag Radial
Nitto 555 Extreme Performance
They also have two NT05 offerings:
NT05 Extreme Summer Performance
NT05 Drag Radial
Discount Tire Nitto Link
Most of the track guys are talking about the Nitto 555 Extreme Performance or NT05 Extreme Summer Performance.
#71
I love my NT-05s! well...whats left of them, lol. definitely not a longevity tire. about 2k DD miles and 4 track days, 2 autocrosses, theres hardly anything left of them.
#72
Also, how does a staggered setup help on the track?
#74
Try the NT05 if you want a dual purpose street/track tire, or the NT01 if you want a track-only tire that will last a few track events.
#75
Originally Posted by 06GT
555s are street tires...they will not have as much grip as the stock Pirellis, IMO.
#76
Agreed...if you're new to track events, don't bother with getting different tires. You won't be going fast enough for it to matter anyways.
#77
So, maybe the better way to go would be to get NT05s in 275/40 on 18x9 for the front and 295/35 on 18x10 for the rear.
Thanks for all the tips!
#78
1 Post
IMO the car is very neutral with a staggered setup of 1" to 1.5" front to rear. If you square up the tires, you're inducing even more oversteer. i.e. the back end is going to want to be your front end when turning. With a staggered setup I can induce all the oversteer I want just with turn-in and throttle steer at will. If you're new to tracking and particularly a high HP rear wheel drive car with a solid rear axle, you'll want to avoid a square setup unless you want to look like a Sit-N-Spin out there
#80
