Oil Pressure Sensor
Oil Pressure Sensor
Hello! First post here. I need your help.
I recently purchase a 2012 LS (#495) with 3500 miles. I was out today and the oil warning light came on plus the oil pressure gauge in the center pod stopped working.
I pulled over and checked under the car for any sign of oil leaking then checked the oil level. No signs of oil leaking under the car and the oil level was a little bit below the top hole on the dip stick. I got back in the car, started it and moved it forward a bit to check the ground for any sign of oil, nothing.
Started it again and drove it home. Thankfully I wasn't far from home when this happened. The car ran fine, no sign of anything unusual except the warning light and oil pressure gauge not working.
My questions is, did my oil pressure sensor go belly up?
After I got home I put the car on ramps and checked things out a little further:
1) No sign of oil leaking anywhere around the pan, pan plug, filter, pan level sensor or pressure sensor/sender on the block.
2) I unplugged and plugged back in the oil level sensor on the side of the oil pan.
3) Tried the track key and even disconnected the battery hoping to reset things in case there was some computer gremlin at work.
4) Scanned for fault codes using ODB2 scanner app, nothing.
5) Used a circuit tester on the wires coming out of the pressure sensor and it lit up fine. (Now that I think about it, I didn't do this on the oil level sensor, will try that too)
Thank you!
Thank you!
eljefe (12/14/17)
Any chance you still have this? I’ve been looking for one for 3 months and haven’t been able to find any. Finally did today and they’re are 8 factory ones left in existence for the small price of $450 shipped. I’ve previously looked for the one pictured but everywhere was out of stock
The Analog Admin!
Received 3,157 Likes
Hello,
We Can Do A Mention and Maybe Get Lucky. Do You Have a Ford Part Number?? If Not A Vin Would Be Helpful! I Have Been Known To Find Hard To Find Parts! You Can PM Me The Vin if You Don't Want to Post it.
Sorry Wrong Guy! Tymeslayer Came in Last Time in 2021! He is Paged!
@TymeSlayer
Mgb,
Kc
@TymeSlayer
Mgb,
Kc
The Analog Admin!
The 8 You Speak of are They on a List From a Ford Dealers Parts Locator System???
KC
KC
The Analog Admin!
https://www.ebay.com/itm/18607607909...3ABFBMsu2v7uJi
How About This???
Better Yet!
https://www.rockauto.com/en/partsear...num=cr3z9d290a
KC
How About This???
Better Yet!
KC
The Analog Admin!
This One Even Has Your White Sticker on it! Same Numbers!
https://www.rockauto.com/en/moreinfo...&pt=4588&jsn=4
Click on Arrow For Pic 2! Cheapest One Too!
kc
kc
The Analog Admin!
Amazon Wants Almost $600.00 For It! What a Joke!
https://www.google.com/search?sca_es...&bih=751&dpr=1
KC
KC
The Analog Admin!
Kc
Technical Details
Manufacturer WVE by NTK Brand WVE by NTK Item Weight 2.72 ounces Package Dimensions 4 x 2.25 x 1.5 inches Country of Origin USA Item model number 1S12020 Manufacturer Part Number 1S12020 OEM Part Number CR3Z-9D290-AThe $149.00 on Rock Auto is The Deal as Far as I Can See! Says 1 Left!
Good Luck!
Kc
Realize Ford Has Somebody Make Their Stuff Would Not Be Surprized if the White Sticker Part is Same as Oem. Especially Such a Limited Use Part. I Know NTK Supplies Some 02 Sensors's For Ford If Memory Serves. Should Be a good Part.
Kc
Good Luck!
Kc
Kc
Technical Details
Good Luck!
Kc
The Analog Admin!
CaptDistraction
12/7/13 03:30 PM
