Oil Pressure Sensor
Hello! First post here. I need your help.
I recently purchase a 2012 LS (#495) with 3500 miles. I was out today and the oil warning light came on plus the oil pressure gauge in the center pod stopped working. I pulled over and checked under the car for any sign of oil leaking then checked the oil level. No signs of oil leaking under the car and the oil level was a little bit below the top hole on the dip stick. I got back in the car, started it and moved it forward a bit to check the ground for any sign of oil, nothing. Started it again and drove it home. Thankfully I wasn't far from home when this happened. The car ran fine, no sign of anything unusual except the warning light and oil pressure gauge not working. My questions is, did my oil pressure sensor go belly up? After I got home I put the car on ramps and checked things out a little further: 1) No sign of oil leaking anywhere around the pan, pan plug, filter, pan level sensor or pressure sensor/sender on the block. 2) I unplugged and plugged back in the oil level sensor on the side of the oil pan. 3) Tried the track key and even disconnected the battery hoping to reset things in case there was some computer gremlin at work. 4) Scanned for fault codes using ODB2 scanner app, nothing. 5) Used a circuit tester on the wires coming out of the pressure sensor and it lit up fine. (Now that I think about it, I didn't do this on the oil level sensor, will try that too) Thank you! |
https://cimg9.ibsrv.net/gimg/themust...cd419560cf.jpg
Hope you got this figured out. Let me know if you need a new sensor. I have a never used spare left over if interested. |
Originally Posted by TymeSlayer
(Post 7023093)
Hope you got this figured out. Let me know if you need a new sensor. I have a never used spare left over if interested. Thank you! I did and I wish I would have known about this at the time. I got raped by the dealership's parts department on the price of the sensor. |
The 2012 LS sensor is 10X the cost of normal GT/ Boss sensor.
The sensor is calibrated to operated the gauge on the center pod. Not just an on/off idiot light sensor. |
(Post 7023093)
Hello,
We Can Do A Mention and Maybe Get Lucky. Do You Have a Ford Part Number?? If Not A Vin Would Be Helpful! I Have Been Known To Find Hard To Find Parts! You Can PM Me The Vin if You Don't Want to Post it. Sorry Wrong Guy! Tymeslayer Came in Last Time in 2021! He is Paged! @TymeSlayer Mgb, Kc |
(Post 7080585)
Hello,
We Can Do A Mention and Maybe Get Lucky. Do You Have a Ford Part Number?? If Not A Vin Would Be Helpful! I Have Been Known To Find Hard To Find Parts! You Can PM Me The Vin if You Don't Want to Post it. Mgb, Kc |
The 8 You Speak of are They on a List From a Ford Dealers Parts Locator System???
KC |
https://www.ebay.com/itm/18607607909...3ABFBMsu2v7uJi
How About This??? Better Yet! https://www.rockauto.com/en/partsear...num=cr3z9d290a KC |
(Post 7080588)
KC |
This One Even Has Your White Sticker on it! Same Numbers!
https://www.rockauto.com/en/moreinfo...&pt=4588&jsn=4 Click on Arrow For Pic 2! Cheapest One Too! kc |
Amazon Wants Almost $600.00 For It! What a Joke!
https://www.google.com/search?sca_es...&bih=751&dpr=1 KC |
Originally Posted by Triple_C_Performance_
(Post 7080603)
I believe so, I didn’t see what website the tech was on but I was at Parts and Service
Kc Technical DetailsManufacturer WVE by NTK Brand WVE by NTK Item Weight 2.72 ounces Package Dimensions 4 x 2.25 x 1.5 inches Country of Origin USA Item model number 1S12020 Manufacturer Part Number 1S12020 OEM Part Number CR3Z-9D290-AThe $149.00 on Rock Auto is The Deal as Far as I Can See! Says 1 Left! Good Luck! Kc |
(Post 7080606)
Realize Ford Has Somebody Make Their Stuff Would Not Be Surprized if the White Sticker Part is Same as Oem. Especially Such a Limited Use Part. I Know NTK Supplies Some 02 Sensors's For Ford If Memory Serves. Should Be a good Part.
(Post 7080607)
Just ordered it. Thanks for the help, I have no idea how I never saw it there before.
Mgb, KC |
